Muffled thumping noise
Old 09-15-2015, 08:40 AM
Dirt Roamer's Avatar
Default Muffled thumping noise
I have a 2006 LR3 with 128g mi and some newer tires. I have a muffled thumping noise that sounds like its coming from the back. The thumping speeds up as I do. It's a lot more noticeable during accelerating from a stop, then road noise drowns it out as I get to highway speeds. After only a year my front rotors are warped. Is it possible the rears are and that's what is making the sound? I've done an inspection of the tires, jacked the thing up to see if there was play in the rear bearing, but there is not.
Old 09-15-2015, 08:44 AM
TOM R's Avatar
Did it start when u changed the tires?
Move back tires to front to eliminate them as issue
Old 09-15-2015, 07:03 PM
It started well after the new tire install and shortly after a trip from MO to CO. Light offroading. I was reading a similar post from 2013 and sounded like he had rear drive shaft issues. I'm going to check that and switch out tires.
Old 09-15-2015, 09:48 PM
houm_wa's Avatar
...haven't heard much about rear drive shaft issues in the 10 years I've been on message boards and owned an LR3.
Old 09-16-2015, 05:52 AM
From old post.......
"NJHokie's AvatarNJHokie , 03-16-2013 09:38 PM
As it turns out, not only the exhaust was bad on this one. That was part of the problem. The real culprit, as it turns out, was the rear drift shaft. The splines and C/V joints are worn out causing the "rubbing" anywhere from 35mph-up. Fix is a new drive shaft.
So many noises, so many fixes! ARgh!"
The "rhythme" of mine sounds too slow to be a shaft....but what do I know..
Old 09-16-2015, 05:02 PM
houm_wa's Avatar
Well....that's one.
Old 09-17-2015, 07:49 PM
Haven't had much time to dig into the issue. I did scoot underneath today to look at the rear drive shaft....and I uhhh...grabbed the shaft..I could push and pull on it and it moves around. Anyone know if the "front shaft assembly" of the rear DS is supposed to move? I figured it would have a solid feel to it. I didn't have time to remove the shield so I just grabbed the front assembly.
Old 09-18-2015, 04:19 PM
unseenone's Avatar
It's probably the Center hanger bearing, at least, and perhaps some slack in the u-joints as well. you shouldn't get much if any movement.
Old 09-19-2015, 11:03 AM
I'm getting all kinds of play at the hanger. Let me know if you can view the video link. How hard is it to replace the bearing?
https://www.dropbox.com/s/971sd6d3ps...05830.mp4?dl=0
Old 09-21-2015, 12:08 PM
Will I need to replace the whole driveshaft due to the hanger bearing failure?
JMYERS23
03-16-2013 09:38 PM
lakebluemickey
09-01-2012 11:51 AM
kskinner
Freelander
10-01-2011 01:50 AM
paso96D1
10-17-2009 08:10 PM
zerochills
04-29-2008 05:33 PM
Quick Reply: Muffled thumping noise
