Need Replacement Key...
Old Jan 21, 2012 | 09:31 AM
escobarIV's Avatar
Default Need Replacement Key...
Somehow I misplaced my key fob.
Haven't been quoted by the stealer for a new key yet but I am guessing the price will be excessive.
I understand that they need to be laser cut in GB and then sent here to be programmed - which could take 3-4 weeks and is absolutely ridiculous. I have also heard that LRNA may be able to cut keys stateside.
Any other alternatives or info?
Old Jan 21, 2012 | 09:57 AM
I bet all your thoughts are on the right path. Even if you were able to obtain a used one, it will likely need to be programmed to the vehicle (trip to dealer or someone with advanced scanner/computer). Rover wants a vehicle that has robust security, so no one can steal the crown jewels; and a vehicle that no one can work on except an authorized dealer, with latest software and well trained experienced techs. They go after this design goal with a zeal that is not matched by some other factories.
Must be working, here's a list of top ten stolen cars (year model), and no Land Rover:
  1. Honda Civic (1995)
  2. Honda Accord (1991)
  3. Toyota Camry (1989)
  4. Ford F-150 (1997)
  5. Chevrolet C/K 1500 (1994)
  6. Acura Integra (1994)
  7. Dodge Ram Pickup (2004)
  8. Nissan Sentra (1994)
  9. Toyota Pickup (1988)
  10. Toyota Corolla (2007
Old Jan 21, 2012 | 11:16 AM
unseenone's Avatar
I am uncertain about getting the key cut. I do know that in order to have a key activated to a vehicle, it must be programmed via the computer system. All keys must be present (so I have heard) at programming time.
Contact the dealer, and ask them if they cut the key there, or if it needs to be ordered cut. Either way, you will need to go to the dealer or use a faultmate or someone with a multi vehicle one to pair it to the vehicle.
I have been thinking about ordered a key online which come uncut, so I would hope there is a way to cut them without sending them back to the uk, or there would be no market for them.
Old Jan 22, 2012 | 12:46 PM
Rovin4life's Avatar
LRNA cuts the keys and we program them. Sorry but thats the facts. its not cheap but its the security that comes along with owning the vehicle. and yes you need all the keys.
Check around with other dealers who knows maybe the local guy may be more then a dealer then is far away. Then you can drive there and get the key cut.
oh and LR law is you must send them a faxed copy of your license, driver registration and deposit for the key. Or you must bring it in person. You are not allowed to just buy the key without the identifying documents. That is also state law.
Old Jan 26, 2012 | 08:20 AM
TXLR3's Avatar
7th Gear
We had to do this about 3 years ago when mine stopped charging itself and would no longer lock or unlock the car. Since it charges from the car and not a battery it had to be replaced. It didn't take 3-4 weeks but did have to be ordered from overseas and the price was around $500. Excessive , yes. Necessary? Yes.
Old Jan 26, 2012 | 09:29 AM
Some guys on here have bought a whole Disco for that....
Old Jan 28, 2012 | 05:32 PM
Could you still unlock the doors and drive the truck with just the key or do you absolutely have to have the remote?
Old Feb 1, 2012 | 09:52 AM
TXLR3's Avatar
7th Gear
You can remove a portion of the door handle to the right of the actual handle which conceals a key hole. The truck will still start with the key as well.
Old Feb 1, 2012 | 05:00 PM
unseenone's Avatar
The battery in the remote can be changed, with some effort. My issue is the rubber is shot, not the battery. If it is useful for the battery replacement procedure, I can post a link.
Old Dec 6, 2022 | 09:41 AM
Junzai983's Avatar
New Member
Steps for Making a Key Without the Original:
Ask a locksmith to provide a few key blanks.
Then, you will need to file that key blank into a sharp point, kind of like a blade, and we do that using a Pippin file.
Once you have that key filed down, use a pair of vice grips to hold the blank firmly.
Or you can also consider this for likewise info
Discolife
Nov 25, 2011 11:38 AM
freelander2002
Oct 27, 2009 05:07 PM
pilsner
Apr 7, 2008 03:24 PM
plastique999
Jan 22, 2008 01:34 AM
Jay
Apr 27, 2005 03:49 PM
