Occupancy Sensor Programming???
Old May 14, 2018 | 11:50 AM
Kenneth Carr's Avatar
Originally Posted by memphis_rover
The staple around here is the Gap Diagnostics IID tool. I have never heard of the one your using. From what I gathered by looking at the ICarSoft page it seems like most of the tools simply scan for codes. The IID tool is great because it also lets you do all the programing and configuration you need. Honestly, every new owner of an LR3 should buy an IID. It will save you money. Ive had mine for less than a year and has saved my butt and wallet numerous times.
I may have to check into the Gap IID if the iCarSoft wont' do it. Found the iCarSoft LR V2.0 on the Atlantic British website. For the price, I doubt it will do the programming, but one of the few I found that specifically said it would read the airbag codes and reset them.
Thanks
Old Aug 28, 2018 | 05:56 PM
BenSchneider's Avatar
6th Gear
I am having the same problems. Did you ever try the scanner and were you able to fix the problem? I am looking at scanners and need to decide on spending $529 on the GAP IID.
Old Aug 28, 2018 | 06:04 PM
houm_wa's Avatar
Easy decision: YES.
Old Aug 29, 2018 | 08:14 AM
Blackngold77's Avatar
absolutely.
pays for itself in no time. being able to go in and reset things and fully diagnose issues is a wallet saver
Old Sep 4, 2018 | 04:50 AM
I ended up not having to reprogram it. Installed a new sensor and no error code ever reappeared and it functions properly.
Atticus_6147
Jun 5, 2019 03:24 PM
bluetick
Jan 6, 2019 08:31 PM
delormea397
Dec 18, 2018 04:55 AM
delormea397
Sep 14, 2018 06:33 PM
Bhalbach
Feb 23, 2018 02:36 PM
