Park Brake Fault
Old Nov 22, 2023 | 08:06 PM
wichipong's Avatar
Default Park Brake Fault
Could a bad bearing cause park brake fault and disable parking sensors??? park brake fault happened when i was doing a u-turn yesterday evening.. it was working earlier in the day... on my way drive home, heard grinding noises when driving which slowed down when i applied the brakes.. otherwise, car driving fine
Old Nov 23, 2023 | 05:34 PM
loanrangie's Avatar
Rear bearing i guess its possible but not heard of it before.
Old Nov 24, 2023 | 01:54 PM
DakotaTravler's Avatar
Sensors, no. They are a fully independent system with the only influence being a trailer connected, etc. Parking brake is an always active system even when not being used. The system monitors parking brake cable tension to keep it in spec. Worn parking shoes, bad adjustment can all eventually throw it out of spec. Per the manual, the parking brake system is something that needs regular maintenance. So I tend to agree that either a REALLY bad rear bearing could cause fault since it may cause issues with brake sho alignment but I would couple that with what could be a poorly maintained parking brake system. I would simply pull the rear rotors and take a look. I bet one side will have worn/damaged shoes. But once in the air and before removing anything, check wheels for play which could indicate bearing failure.
Old Nov 27, 2023 | 12:11 AM
wichipong's Avatar
i just had all rotors and brake pads replaced a couple of months ago. bringing the truck to my mechanic tomorrow to get the shoes checked.. hopefully its a cheap and easy fix
Old Nov 28, 2023 | 12:08 AM
wichipong's Avatar
UPDATE: Left side parking brake cable snapped.. Hopeful that the module is still good.. now trying to source the cable/part.. Question is do i replace both or just the bad side?
Old Nov 28, 2023 | 04:47 PM
I would do both. But they are hell to replace if you have any rust on that thing. The plastic end never want to easily unthread from the shields. Also never head or a cable snapping before, that is a new one.
SiJersey
Jul 11, 2023 06:01 PM
Baja1967
Aug 1, 2022 05:08 PM
Disco4LoverSA
LR4
Aug 4, 2021 11:18 PM
Alva312
Oct 19, 2014 10:36 AM
wassa66
Jul 4, 2012 04:14 AM
