Parking Brake Fault Post Rear Brake Job
Old 10-16-2020, 07:08 PM
evsteroo's Avatar
Planetspacerover, did you ever resolve this issue? I'm stuck with a flashing red park light and an intermittent amber brake light. The fault is the same as yours. On mine I can confirm unjam DOES work and move to latching or mounting DO NOT work and simply cause the EPB module to intermittently throw the temperature sensor code.
Old 10-16-2020, 07:57 PM
planetspacerover's Avatar
From disconnecting the battery, to manually readjusting the rear brake shoes, to playing around with settings using the GAP tool, nothing got rid of the flashing red lights, alarms, and over temperature fault.
Land Rover replaced the EPB module for $1900.
Old 10-16-2020, 08:14 PM
evsteroo's Avatar
That's not great to hear. I posted my own thread about the EPB fault I'm dealing with; it seems to be very similar to yours. I confirmed, with the cover off and using the "unjam" command in the GAP tool that the motor does work and is not jammed, but the EPB module won't accept commands to move to "latching" or "mounting" either via the GAP tool or with the parking brake switch.
Old 05-26-2024, 03:48 PM
johnsonmc2000's Avatar
@evsteroo did you solve the fault? What was it? Mine just did same.
rlj174
01-11-2022 06:57 PM
ponderosajack
11-04-2019 04:08 PM
TEX_Rover
08-28-2017 12:46 PM
wassa66
07-04-2012 04:14 AM
forestry17
05-12-2012 05:07 PM
Quick Reply: Parking Brake Fault Post Rear Brake Job
