Radiator Leaking - what else should I fix
Old Mar 4, 2025 | 03:22 PM
MaineLR3's Avatar
Default Radiator Leaking - what else should I fix
Hey folks,
2008 LR3 4.4L 214K miles. I smelled coolant today when I got home, checked around and found the passenger side of the radiator is leaking. Nothing bad but coolant is definitely seeping out. Question is, what else should I replace while I'm in there? This is my list so far, all these components are original as far as I can tell so everything but the radiator is 'preventative'.
  • Radiator
  • Cooling system hoses (Atlantic British sells a kit with all of them, it's a bit pricey $700 but while I'm in there...)
  • Water pump
  • Thermostat / housing
  • Belts
What else have you replaced while that part of the world is easily accessible?
Old Mar 4, 2025 | 08:49 PM
loanrangie's Avatar
Check the belt tensioner and idlers as well, you may be able to replace the bearings in the pulleys instead of replacing them.
Old Mar 6, 2025 | 05:36 PM
DakotaTravler's Avatar
This might help you a little. I did my radiator not too long ago as well as every hose except the ones running back to the heater cores. I will do those this spring.
https://landroverforums.com/forum/lr...-hoses-123393/
Old Mar 6, 2025 | 06:43 PM
MaineLR3's Avatar
Wow this is gold, thanks @DakotaTravler !!
droolyFace
Jun 17, 2024 12:24 PM
Bobber
LR2
Apr 2, 2024 09:06 PM
Jason Feuerstein
Mar 9, 2020 07:52 PM
Daedrix
Dec 21, 2013 10:45 AM
dc10freighter
Aug 19, 2007 10:14 PM
