Radiator Leaking - what else should I fix
Hey folks,
2008 LR3 4.4L 214K miles. I smelled coolant today when I got home, checked around and found the passenger side of the radiator is leaking. Nothing bad but coolant is definitely seeping out. Question is, what else should I replace while I'm in there? This is my list so far, all these components are original as far as I can tell so everything but the radiator is 'preventative'.
- Radiator
- Cooling system hoses (Atlantic British sells a kit with all of them, it's a bit pricey $700 but while I'm in there...)
- Water pump
- Thermostat / housing
- Belts
This might help you a little. I did my radiator not too long ago as well as every hose except the ones running back to the heater cores. I will do those this spring.
https://landroverforums.com/forum/lr...-hoses-123393/
