Radio Aux Input Volume Booster
Old Apr 15, 2016 | 10:02 AM
ljdiscovery's Avatar
Default Radio Aux Input Volume Booster
Some time ago I saw a post that someone had used a wired-in device to boost the input of ipods, etc. through the aux input plug. I have noticed a big difference on the volume using the radio/cd vs. the Aux. plug. Did a search and can't find the thread. I did find a battery operated solution but it was $99, a bit steep. Does anyone recall the thread or has anyone used another device or found a solution for the volume issues with the aux plug? thanks Phil
Old Apr 15, 2016 | 10:25 AM
DavC's Avatar
When I looked for the same thing you're looking for I found that PHP sound shocker and the sound shocker pro. The pro is definitely way too much, the quality got way worse but volume was higher. I MIGHT try the normal sound shocker but I doubt it will help that much. The guy who makes them was pretty nice about me returning mine. So maybe worth a try.
This is what I use for music, volume is good, just need to crank it a bit (around 22-28 is great). A few others have used them with success.
http://www.amazon.com/HomeSpot-NFC-enabled-Bluetooth-Audio-Receiver/dp/B00G57CWZ8 http://www.amazon.com/HomeSpot-NFC-enabled-Bluetooth-Audio-Receiver/dp/B00G57CWZ8
at least a year old and still going strong. EDIT: the bluetooth bit is not for increasing aux input, but works pretty well, and is a little louder than standard phone to aux to stereo.
Old Apr 15, 2016 | 10:40 AM
DustyLBottoms's Avatar
I bought one of these last month and easily wired it in:
RCA Audio Amplifier Pre Amp Adjustable Line Driver Signal Booster LD10 Red White | eBay
If you end up buying it gimme a call and I can walk you through the steps.
Old Apr 15, 2016 | 04:21 PM
The RCA Audio Amp looks interesting. How did it turn out for you. Did it give the aux in the boost needed? If so, I am getting one or two. One for the LR3 and one for the Range Rover Sport. How does it wire in? thanks Phil
Old Apr 15, 2016 | 05:04 PM
Turned out great. The unit has separate gain controls for left & right channels. I bypassed the factory plug, and ran a new aux-in cord out my center console. It's pretty easy if you can crimp.
Chuck Cheeze
Oct 5, 2015 12:49 PM
MINIrover
Jul 20, 2011 10:46 AM
arijfeli
May 3, 2008 01:35 PM
nrwater
Jul 29, 2007 12:47 PM
nrwater
May 2, 2007 11:21 AM
