Rear Diff Motor Replacement
Old Jun 3, 2019 | 08:37 AM
Philip Chan's Avatar
Default Rear Diff Motor Replacement
I am about to embark on the replacement of the locking motor for my rear diff. Does anyone have any good hints as to how best to do this?
I've seen a variety of methods listed from going in through the DS rear wheel well to coming up through the spare tire space and removing this, that and the other.
I know that LR techs will drop the diff. I hope to avoid that.
Thanks.
Old Jun 4, 2019 | 11:52 AM
abran's Avatar
LR techs don't drop the diff. You can get to it from below. Spray the connector down with brake cleaner then a little wd40. It can be hard to turn(its one of those 1/4 turn style connectors that are on the trans).
I believe its 4-8mm bolts. A little tight, but not terrible.
Old Jun 4, 2019 | 02:35 PM
Thanks for the info. Have you actually done this yourself? (no offence - but just looking for someone who has been and done). Any tips for tools, etc.?
Old Jun 4, 2019 | 04:22 PM
houm_wa's Avatar
Hahahahahahahaha........
Old Jun 4, 2019 | 04:25 PM
abran's Avatar
I've done it at least 5 times. I have used a small set of channel locks to turn the connector, but be gentle to not break it.
I think the connector is the hardest part.
A U joint 8mm socket might help get the 4-8's.
Here is a photo of one we have on the shelf:
Old Jun 4, 2019 | 04:27 PM
abran's Avatar
Old Jun 4, 2019 | 04:39 PM
abran's Avatar
what? you doubting him doubting me... I doubt it!!!
Old Jun 4, 2019 | 04:40 PM
abran's Avatar
And to clarify, I run an indy shop and we pretty much specialize in LR3s, and I drive an HD.
abran's Avatar
Connector for reference:
Old Jun 4, 2019 | 07:51 PM
Hey - thanks for this. I only asked not because I doubt you, but there's lots of info on here and other places from people who have not done it - just read or "heard about how to do it". I value the advice, but need to know if coming up from underneath it's doable - which it seems it is. I will have to give it a look because I didn't think it possible. But what do I know...
