Rear Diff Motor Replacement
Old Mar 2, 2021 | 07:18 PM
  #61
houm_wa's Avatar
Ahhhh....yeah you could probably benefit from that block heater in WI. I hardly need it in WA, but like I said....the Yukon. I still plug it in on nights that are gonna dip below 30F (still not needed, I know) but those are few and far between around here. I don't regret swapping the center console covers. I got a good deal online and then I sold my old one (it was in pristine shape) for a pretty good price. The net cost was not much at all...maybe a hundred bucks.
How did you know the SEs you saw had adaptive headlamps? Did you see the lights do the dance? Just curious, because they of course look the same when static. They would have to be a retrofit.
Old Nov 15, 2025 | 04:48 PM
  #62
Traveler54's Avatar
Default Quick question about the e-diff motor housing
Originally Posted by abran
I've done it at least 5 times. I have used a small set of channel locks to turn the connector, but be gentle to not break it.
I think the connector is the hardest part.
A U joint 8mm socket might help get the 4-8's.
Here is a photo of one we have on the shelf:
Hello - is there a gasket between the diff and the motor housing? If not, do the mating surfaces require liquid gasket material?
Old Nov 15, 2025 | 04:51 PM
  #63
DakotaTravler's Avatar
No gasket. Just use quality high temp sealant. Reinzosil is my go-to sealant of choice.
cgray11
Oct 24, 2014 08:37 PM
oljohnboy
Jun 9, 2014 10:57 AM
khentige
Oct 23, 2012 09:34 PM
SWAINROVER
Oct 4, 2011 09:41 PM
Classic89
Sep 3, 2007 09:04 PM
