Rear Diff Motor Replacement
Old Jun 4, 2019 | 09:53 PM
Originally Posted by abran
what? you doubting him doubting me... I doubt it!!!
Lol...
Old Jun 4, 2019 | 09:59 PM
houm_wa's Avatar
Default No worries Philip...
....Abran is a legend on this board, that's why I laughed. I know you didn't know but now you know so good to know, huh?
Old Jun 5, 2019 | 11:04 AM
abran's Avatar
Thanks @huom_wa.
the truth is, I’ve never actually changed one... but I did stay at a Holiday Inn express last night!
abran's Avatar
Originally Posted by Philip Chan
Hey - thanks for this. I only asked not because I doubt you, but there's lots of info on here and other places from people who have not done it - just read or "heard about how to do it". I value the advice, but need to know if coming up from underneath it's doable - which it seems it is. I will have to give it a look because I didn't think it possible. But what do I know...
All good, lots of bogus info out there.
Old Jun 6, 2019 | 10:20 PM
Philip Chan's Avatar
So I scoped out the "route in" tonight. Seems the front two bolts are ok. The back drivers side is doable, but the other side at the back - forget it. How the heck am I supposed to reach that? I can get my fingers on it, but positioning a socket on it even with a U-joint is almost impossible. Better if the exhaust or the drive shaft wasn't there, but I'm not removing those.
Is there a best practice here to get those?
Again - I've seen a post whereby access to the back bolts was through the spare tire well and then removing the evaporator canister (?). Mine bolts on that are solidly rusted in so I don't know if I should even attempting a Dremel on that and then replacing them...
one step forward...three back.
Old Jun 7, 2019 | 01:11 PM
abran's Avatar
I use 1/4” u joint 8mm socket:
Old Jun 7, 2019 | 10:34 PM
No dice - I don't have a u joint set like this - just an adaptor. I still can't get to the last bolt - passenger side back. I think I'll have to go through the spare tire space. I managed to get three of the four loose. Compounded to that, I have no idea how I'd. reach the connector.
That and probably my arm and hand is too fat
I tried going in through the left rear wheel too. That was even more difficult.
I noticed though that the bolts that hold the evaporations. canister on are rusted solid. I'll have to cut them and then run a new bolt. So damn annoying.
Old Jun 8, 2019 | 11:33 AM
abran's Avatar
good luck
Old Jun 8, 2019 | 12:02 PM
I’d just make a quick run to the tool store and pick up the swivel sockets but that’s me
Old Jun 8, 2019 | 01:32 PM
DakotaTravler's Avatar
Are there two different sets of bolts that could be removed to do this task? You have the four on the motor unit. These are horizontal (blue dots). Then there are four on the housing (purple dots), these are for the most part vertical. Just curious.
