Rear Diff Motor Replacement
Old Jul 3, 2019 | 09:16 PM
  #41
Philip Chan's Avatar
If it’s the silver module that your talking about. Clean it with CRC Electronic cleaner, and a soft bristle tooth brush. Clean the harness and the module coat with dielectric grease and see if its better
Hi. Yes I cleaned this out on the weekend. Still no joy. I think I might inspect the wiring bundles that run down and to the passenger sill. This is where I discovered a lot of water when I first got the car due to , I believe , the a pillar leaking.
Old Jul 5, 2019 | 05:55 PM
  #42
I'm wondering why the reset on the Diff motor cannot be achieved? Why can these faults not be cleared and why can't it be calibrated?! @abran @DakotaTravler ? ideas?
Rear Diff
  • P0806-00 (2F) Clutch position sensor - circuit range/performance
    ( at 0 km )
  • P080A-00 (2F) Clutch position is not learnt
    ( at 0 km )
  • P0810-92 (28) Clutch position control error - Component failure - performance or incorrect operation
    ( on 04-07-2019 12:41:58 at 202436 km )
Old Jul 5, 2019 | 11:19 PM
  #43
abran's Avatar
No idea. Bring it to my shop, I’ll fix it.
Old Jul 7, 2019 | 08:58 PM
  #44
I'd love to. Little too far . lol.
2 questions - 1) Does the electronic rear Diff module go bad? is this likely to need replacing if it cannot be reset?
2)For the diff motor itself, is it really sensitive too torque settings that may be over and above? (i.e. could this be the issue for not resetting?)
Old Jul 8, 2019 | 12:28 AM
  #45
abran's Avatar
Did you replace with a used or new motor?
Old Jul 8, 2019 | 09:14 AM
  #46
I replaced it with this:
https://www.ebay.ca/itm/NEW-Rear-Dif...72.m2749.l2649
Which I think is a yes ....
Old Jul 8, 2019 | 09:36 AM
  #47
abran's Avatar
Rear dif module can go bad, but it’s more likely the motor.
the torque is 4 bolts that hold down the gear plate, I don’t see how that would effect the motor.
Old Jul 16, 2019 | 06:20 PM
  #48
Update -
Need a new rear diff.
Apparently the pre tension has gone from the locking mechanism. Someone probably removed the locating pin at some point and it unravelled the tension that is in the assembly. Not sure how much to rebuild yet - but there you go.
Abran - may a quote on one of your diffs would be good about now
Old Feb 9, 2020 | 11:02 PM
  #49
Reviving this thread as it never seems end...
  • Pretty much resigned myself that I had to replace the diff.
  • Someone suggested I try the module - cheap enough just to try. If it fixes it, much cheaper than a new diff.
so...
  • Bought a used rear diff locking module and installed
  • Didn't fix it, but the rear diff acts differently
    • I used to get a whirring from the diff motor on start up and shut down. Now it *seems* I only get the whirring it on start up. It's like it's trying to find a place or setting internally
    • The code is still there for P0806-00 (2F) Clutch position sensor - circuit range/performance, but not the others... (clutch position not learned etc.)
    • On start up once or twice the transmission issue didn't come up. Only on driving did it reappear.
I am so hoping I do not have to replace the whole thing. I just wish there were more people who knew about these things...!
Old Feb 10, 2020 | 09:14 AM
  #50
DakotaTravler's Avatar
Did you calibrate it? Calibration is required for swapping the motor although there is one 'brand' on eBay that says theirs does not require it.
