Rear Wiper failing?
Old Feb 17, 2023 | 10:45 PM
elemental_garage's Avatar
Default Rear Wiper failing?
My rear wiper appears to be having a harder and harder time making a full sweep. Lately, it's been getting stuck mid-way. It'll move about an inch each time I command it to but appears to struggle more and more. I'm pretty sure the motor is going out and needs replacing but just wanted to double-check in case there are other gremlins unknown to me that you all have experienced with these symptoms.
Cheers, all!
Old Feb 18, 2023 | 12:38 AM
loanrangie's Avatar
Could be the motor or could be the plastic gear or slider that keeps the rack engaged with the shaft gear, gear can be 3D printed but the slider will need to made.
I went thru 2 motors, first one the gear split in half and the slider broke , the 2nd the gear was good but slider also broke.
I have a length of HDPE that i made the slider from.
Old Feb 19, 2023 | 09:46 AM
Okay sounds like I need to take it apart and see whats going on.
Appreciate it!
lipadj46
Apr 19, 2020 11:56 AM
slskier88
Feb 18, 2015 01:34 PM
OffroadFrance
Feb 21, 2014 08:40 AM
discoboy
Dec 15, 2008 03:22 PM
esaycho
May 11, 2006 07:29 PM
