Rear Wiper failing?
Old 02-17-2023, 10:45 PM
elemental_garage's Avatar
Default Rear Wiper failing?
My rear wiper appears to be having a harder and harder time making a full sweep. Lately, it's been getting stuck mid-way. It'll move about an inch each time I command it to but appears to struggle more and more. I'm pretty sure the motor is going out and needs replacing but just wanted to double-check in case there are other gremlins unknown to me that you all have experienced with these symptoms.
Cheers, all!
Old 02-18-2023, 12:38 AM
loanrangie's Avatar
Could be the motor or could be the plastic gear or slider that keeps the rack engaged with the shaft gear, gear can be 3D printed but the slider will need to made.
I went thru 2 motors, first one the gear split in half and the slider broke , the 2nd the gear was good but slider also broke.
I have a length of HDPE that i made the slider from.
Old 02-19-2023, 09:46 AM
Okay sounds like I need to take it apart and see whats going on.
Appreciate it!
lipadj46
04-19-2020 11:56 AM
slskier88
02-18-2015 01:34 PM
OffroadFrance
02-21-2014 08:40 AM
discoboy
12-15-2008 03:22 PM
esaycho
05-11-2006 07:29 PM
Quick Reply: Rear Wiper failing?
