Rough day in the LR3 bleeder blow out
Old Aug 17, 2017 | 10:09 PM
Default Rough day in the LR3 bleeder blow out
So I came across LR3 number 1 broke down on my way home.
Seems that it was overheating. So I called the Rover back up powertrain system... While I was waiting I played around with tablet fitting ideas and have that planned out and watched a classic movie.
Once home I got under the hood and found the culprit. A cheap plastic T connection with the bleeder.
Wasn't sure if there was supposed to be a third hose or if was the bleeder for sure. So I pulled the engine cover and checked the other LR3, twins are handy sometimes.
So not interested in plastic for a replacement a little trip to Home Depot found me with brass parts to make a new 2 with bleeder.
Thought I was good to go, but found that thermostat housing had sprung a leak as well. So hopefully I can get one over-nighted so I can get the truck back on the road.
Attached Thumbnails Rough day in the LR3 bleeder blow out-35805817394_ac554ec0fd_z.jpg   Rough day in the LR3 bleeder blow out-36502802571_0b03879585_z.jpg   Rough day in the LR3 bleeder blow out-36640408765_2e47eafa51_z.jpg   Rough day in the LR3 bleeder blow out-36502797931_54faf00c55_z.jpg   Rough day in the LR3 bleeder blow out-36594094186_2c153a7dda_z.jpg
Rough day in the LR3 bleeder blow out-36640414245_ab8ddd158e_z.jpg   Rough day in the LR3 bleeder blow out-36594098696_ff34f8136f_z.jpg   Rough day in the LR3 bleeder blow out-35805844824_3227e3bfb6_z.jpg   Rough day in the LR3 bleeder blow out-36244295030_1f4849ae13_z.jpg
Old Aug 18, 2017 | 10:45 AM
Looks like I am in luck and Lucky8 will have a new thermostat housing assembly at my door step tomorrow
Old Aug 20, 2017 | 08:38 PM
Decided to be smart and make up a second brass T for the other LR3 to be ahead of the power curve. This one was not leaking but was in 6 pieces inside the hoses...
Guys be proactive spend the $15 on the brass parts at Home Depot, Lowe's Napa or anywhere you can get the brass fittings and save yourself some serious grief.
Old Aug 20, 2017 | 09:46 PM
Geo's Avatar
Geo
Great tip. Did the new thermostat housing have a new plastic fitting? Having mine changed now and wondering if this is something that I should still do.
Old Aug 20, 2017 | 09:50 PM
Are you meaning did it have a new T fitting included?
Old Aug 23, 2017 | 08:29 PM
So I got the thermostat housing swapped. I did not take pictures like I planned it was to damn hot and I was to damn frustrated.
It is actually fairly straightforward and easy to do aside from the bottom bolts on the housing. They are just a nightmare to get to.
No leaks and is holding temp just fine. Motor sounds good so I think disaster was averted on this one.
We are not going to discuss my anger issues with getting the old one out
Attached Thumbnails Rough day in the LR3 bleeder blow out-36719968976_604d6077bc_z.jpg
Paul Grant
Oct 19, 2010 07:10 PM
willlane
May 11, 2010 05:09 PM
Eak69
Apr 4, 2010 11:52 AM
ogden45
Dec 29, 2008 08:29 AM
PITTDISCO
May 31, 2008 12:26 PM
