Steering Wheel Volume Controls ?
Old Jan 15, 2013 | 09:32 AM
slickzero76's Avatar
Default Steering Wheel Volume Controls ?
I have a 2006 LR3 SE. On the right side of the wheel I have volume up and down and arrows to change radio presets or tracks on CDs. The problem I am having is the volume buttons change presets and the arrows will change from radio to satellite to phone. This problem is intermittent. Some days it works like it is supposed to. Other days if I push the buttons rapidly I can get it to work the way it is supposed to. Any suggestions???
Old Jan 15, 2013 | 11:29 AM
see attached wiring diagram. The remote control run is a two wire circuit that goes thru the rotary coupler clock spring to allow wheel to turn and make contact; and then there are multiple buttons. Note that a resistor is in series between each button. Back in the radio head unit the resistor value is calculated and it "knows" which button has been pressed. But if there is any corrsion on the contacts of the connectors from the radio to the clock spring to the module that can make resitance chage as well. Corrosion loves to change resistance in temperature swings. I guess you could warm up an area of the steering wheel with a hair dryer (warm, not melt) to test.
File Type: pdf
derohanes
Sep 9, 2012 08:46 PM
Silhernan2
Jul 12, 2012 04:06 PM
etprimus
May 17, 2007 02:07 PM
WGM
Audio/Visual Electronics
Apr 14, 2007 10:32 AM
Petes 03 Rig
Jan 5, 2006 08:13 PM
