Thumping noise
Old Feb 23, 2013 | 10:01 PM
houm_wa's Avatar
The original question seems sorta obvious; of course new is better...but more expensive.
Old Mar 13, 2013 | 11:12 AM
NJHokie's Avatar
I had the same type of noise on my, new to me, 06 LR3 V8 and the LR tech has found it to be the exhaust system itself. The baffles in the mufflers are going bad causing the noise. Same thing as you, only appears when under power, more apparent when in a high gear and going around 40mph, lagging the engine a bit, or going up a hill.
Fix is the fit a new exhaust from the cat back.
Hopefully this solves it for me, check your truck as well.
New OEM exhaust on order.
Old Mar 16, 2013 | 09:38 PM
NJHokie's Avatar
As it turns out, not only the exhaust was bad on this one. That was part of the problem. The real culprit, as it turns out, was the rear drift shaft. The splines and C/V joints are worn out causing the "rubbing" anywhere from 35mph-up. Fix is a new drive shaft.
So many noises, so many fixes! ARgh!
kskinner
Freelander
Oct 1, 2011 01:50 AM
NhudeST
Sep 1, 2011 11:22 AM
paso96D1
Oct 17, 2009 08:10 PM
zerochills
Apr 29, 2008 05:33 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
