Transfer Case Royal Purple Oil
Old Jan 28, 2018 | 04:21 PM
  #21
m_lars's Avatar
Originally Posted by abran
Genuine Land Rover with the "Gore-Tex"logo on it?
Yep, sure does.
Old Sep 17, 2018 | 07:50 PM
  #22
mklinker's Avatar
Originally Posted by spannermonkey
Front diff and transfer case both changed this weekend and both perfectly normal. That's good as it shows the noise is not likely to be any significant wear in either of the diffs or the transfer case as there was nothing on the diff plugs or the transfer case which I put a magnet on. I've also check the carrier bearing again today and no play there. So the bad news is I still don't know what is causing the noise and its getting worse, pretty much constant now.
I don't think its a wheel bearing as its just not got the traditional symptoms of that, but I'll check them all next weekend.
Did you ever figure out what was causing the humm humm humm?
Old Sep 18, 2018 | 04:53 AM
  #23
spannermonkey's Avatar
Yes, It turned out to be a front hub in the end. After several oil changes of the diffs and T-case and seeing no issues I had to let the noise get worse. It was still a bit of a guess in the end, but it seemed to be the logical choice given when I would hear the noise and that eventually it would become ever so slightly more noticeable during a left turn. It was a pig of a job to change though as it was utterly seized. I had to use a blow torch and sledge hammer to get it to budge - needless to say a front alignment was then required
Old Sep 18, 2018 | 07:38 AM
  #24
mklinker's Avatar
That is certainly interesting. I've been dealing with a similar noise that I couldn't find a whole lot of information about, its funny that I found your thread while looking up royal purple transfer case lube.
adwarren78
May 19, 2015 09:15 PM
flwoodsman78
Aug 2, 2014 06:49 PM
meltdowndave
May 19, 2008 07:53 PM
sailorcolin
Feb 21, 2008 05:08 PM
sailorcolin
Feb 12, 2008 03:50 PM
