Transmission cooler pipes... any tips?
Old Jun 17, 2018 | 03:31 PM
CoopLR3's Avatar
Default Transmission cooler pipes... any tips?
I am having trouble removing the old transmission cooler lines on my 2005 LR3 V8 (badly rusted and leaky). It looks like I may have to disconnect the drive shaft, lower the front differential, or raise the tranny a few inches. I have been unable to locate a good write up and this is not in the repair manual. Anyone with experience have a good method?
Old Jun 17, 2018 | 07:21 PM
abran's Avatar
I’ve dove it once.
Im pretty sure I unbolted the front driveshaft, but didn’t remove it.
Old Jun 21, 2018 | 06:18 AM
CoopLR3's Avatar
Thanks Abran... I unbolted the front driveshaft at the differential, but it won't budge. Soaking it in PBlaster and hammering.
I did manage to get the old ones out by rotating them (quite fiddly) so the tranny ends were pointed down. Disconnecting the breather tube from the diff helped. Not sure I can get the new ones in that way though! I'll try tonight. Maybe I should disconnect the shaft at the transfer case too? (PIA!)
Old Jun 21, 2018 | 08:07 AM
abran's Avatar
Yes, unbolt at both ends.
I give the flange on the diff/t case a few love taps on the side with a brass hammer, turning it a little every tap. Good luck.
Old Jun 22, 2018 | 06:34 PM
CoopLR3's Avatar
Again thanks Abran. The drive shaft was just plain stuck, and I feared loosing the end cap and bearings if I worked it too hard. Surprisingly, I managed to replace the pipes without removing the driveshaft or exhaust, or dropping the tranny or diff. It took a LOT of patience and problem solving luck, but it was worth it. Blowing air thru the pipes confirmed several pinholes. Putting 'er back together this weekend and working on a write up. I'll mention your driveshaft tip, sure would have made it easier!
Old Apr 30, 2024 | 12:05 AM
3veris's Avatar
3rd Gear
if you have tips on how you did this, would greatly appreciate it. About to tackle this job and not removing the tranny and diff sounds great.
TheMgmt
Feb 10, 2019 08:19 PM
toofaroffroad
Jun 4, 2018 09:17 PM
TaylorCadence
Apr 17, 2018 02:11 PM
Discolife
Jul 6, 2012 10:08 PM
atancreti
Jul 13, 2011 10:20 PM
