Transmission Fault!!!
Old Nov 9, 2019 | 08:44 AM
Brosnan's Avatar
Exclamation Transmission Fault!!!
HELP!!! 2007 LR3 Went to start her this morning, turns over fine but won't go into gear, any gear; warning light says; "Transmission fault, limited gears only" But it drove home fine last night... Had some work done on it yesterday, the break switch was changed out, could that be the issue? It was working fine, but as I say, this morning, no gears!!!!
Any thoughts please on things to check. TY
Old Nov 9, 2019 | 08:58 AM
DakotaTravler's Avatar
Did you shut it down and restart it? If a restart does not work try turning the headlights on manually before starting.
Old Nov 9, 2019 | 09:06 AM
Brosnan's Avatar
Yes, i've done that, lights on, lights off restarted, no change. However, I did notice that the Air suss compressor just went on, i'm wondering if the battery is going bad? Even though it turns over, I know the battery needs to be A1 right? Had the alternator checked last week and was told it's fine, so, battery? Thanks for your time
Old Nov 11, 2019 | 02:48 PM
houm_wa's Avatar
....could it be that RF Capacitor that bolts onto the tranny?
Old Nov 11, 2019 | 06:25 PM
^ Damn, always forget about that evil thing (something I need to order for myself). The nice thing is on the LR3 is unplugging it causes things to work fine again. On the LR4, not so much.
WALLACEJ
Mar 30, 2021 05:01 PM
gbay
Sep 13, 2019 01:54 PM
Jtm123
Mar 20, 2017 10:17 AM
GWDRoverTX
Jan 16, 2013 10:22 PM
ceven18
Feb 28, 2008 09:55 PM
