Transmission fault message- codes related?
Old Sep 17, 2024 | 08:02 PM
Dizzle1085's Avatar
Default Transmission fault message- codes related?
I have a 2006 LR3 that displays a Transmission Fault message every now and then. It does not affect the drivability of the car as far as I can tell. I pulled the following codes. Are these all related? Maybe a brake switch issue?
U0155-87 Loss of comm with instrument control module (Permanent)
U0102-87 Loss of comm with transfer case module (Intermittent)
U0132-87 Loss of comm with ride level control module (Intermittent)
U0127-87 Loss of comm with tire pressure monitor module (Intermittent)
Old Sep 17, 2024 | 10:01 PM
houm_wa's Avatar
Usually "Loss of comm" messages don't mean anything. How healthy is your battery?
Old Sep 18, 2024 | 07:10 AM
Dizzle1085's Avatar
Battery has tested fine. I cleaned the connecting on the TCM as well. There was a tiny bit of corrosion on the prongs. This just annoys me more than anything as I want everything to be sorted out.
Andreas
Range Rover L405 (Fourth Gen)
Jun 23, 2025 04:58 PM
ThorInc
LR2
17
Mar 3, 2022 02:38 PM
aaronjb
Oct 31, 2021 02:37 PM
Cn17
LR2
Apr 30, 2021 08:27 AM
Andrew kiwi
Aug 10, 2020 02:47 AM
