Transmission woes
Old Sep 3, 2013 | 07:29 PM
nelsam06lr3's Avatar
4th Gear
Default Transmission woes
So I'm studying abroad in China and my sends me an email stating that she took her LR3 in to the shop because a fault light came on and they told her that she needs a new transmission. She said that the car has been driving fine and nothing seems to be wrong with it besides the fault light and it not letting her put it in gear once yesterday before going to work. Has anyone heard about a transmission needing to be replaced with out any prior problems?
Old Sep 3, 2013 | 08:41 PM
stmcknig's Avatar
A second opinion costs nothing...
Old Sep 3, 2013 | 08:55 PM
jafir's Avatar
It would be nice to know the fault.
Old Sep 3, 2013 | 09:32 PM
4th Gear
She is going to check out two places tomorrow. I will let you know what she says the problem is.
Old Sep 4, 2013 | 09:51 AM
4th Gear
the fault codes are as follows
U0402-94
P0613
Old Sep 4, 2013 | 11:29 AM
stmcknig's Avatar
I'm sure more knowledgable folks will be along shortly but the CEL fault codes can be thrown also by a bad connection or even poor battery voltage. If it were my LR and the transmission did not exhibit any physical issues I would reset the codes and see what happens for the next few days and see if they come back...
YMMV.
Old Sep 4, 2013 | 11:42 AM
And keep in mind the service writer and mechanics have been to human resource mandated sensitivity training for dealing with females not accompanied by males. It is great to find a hard working honest indy shop.
P0613 -
What does this mean?
OBD Code P0613refers to
The Engine Control Module (ECM) or Powertrain Control Module (PCM) has detected an internal failure in the Transmission Control Module (TCM).
Symptoms
Possible sumptoms of OBD code P0613
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0613
- Transmission control module circuit open or shorted - Poor transmission control module electrical connection - Faulty Transmission Control Module
All that said, the TCM is inside the tranny and can be replaced as part of the valve body, won't be cheap. Would be worth your while to have electrical plug opened and cleaned up, even throw in a new battery or have existing one charged up. Shop manual pages on what is involved with TCM attached. Some dealers just consider swap out whole transmission.
File Type: pdf
Old Sep 5, 2013 | 05:11 AM
4th Gear
thanks she is taking it to two other places to see what they come up with. I will tell her about the battery and see if that helps.
abrady
Apr 2, 2012 10:35 AM
tubegut
Feb 24, 2010 09:59 PM
werldcup
Mar 10, 2007 06:54 PM
chrisusvi
Feb 27, 2006 02:36 AM
nomadix
Jun 24, 2005 03:19 PM
