What this bolt for?
Old Feb 18, 2024 | 01:07 AM
Dai20bt's Avatar
Default What this bolt for?
Went to remove undercarriage plate to change oil on 2008 lr3 and found this. This looks important given the size. I still haven’t found where this bolt could’ve fallen out of and hope someone has a clue. I had front control arms replaced a couple months ago so need to check if mechanics know anything. Thanks for helping.
Old Feb 18, 2024 | 08:12 AM
Rufflyer's Avatar
Default It may be important
The fact that it has a hex shape at the end makes me think suspension or diff mount. Since it was in the under shield, I have to ask, Did you have a shop do any front diff or front suspension work lately? It is not uncommon for mechanics to drop the new bolt in a place that is too time consuming or difficult to recover and just put the old bolt back in.
Not completely unrelated but there is a reason that a single 10mm socket is the number one seller on most of those tool trucks that stop by the shop each week.
Other than that.... I have nothing.
Jeff
Old Feb 18, 2024 | 11:50 AM
Dai20bt's Avatar
Jeff
thanks for the clues Jeff. Front control
arms were just replaced a couple months ago so will see if mechanics remember dropping any bolts
Old Feb 18, 2024 | 03:20 PM
houm_wa's Avatar
It looks like one of the bolts that attach the control arms. I'd start by checking all those attachments points.
Old Feb 18, 2024 | 06:31 PM
loanrangie's Avatar
Looks unused too, so i'd be checking them ASAP.
TXTBOOK
Jan 21, 2023 06:54 PM
231john
May 21, 2020 08:52 PM
adolfojbonilla
May 2, 2016 11:31 AM
bballjames
Nov 4, 2013 02:17 PM
Darover
Nov 5, 2008 02:36 PM
