What did you do to your LR3 today?
Old Jun 16, 2021 | 12:50 AM
  #1631
enb54's Avatar
Originally Posted by Alex J
Replaced my front suspension valve block with an extra one I rebuilt ahead of time. Also found you do not have to take the whole liner out, 3 screws and one push pin is plenty. The flat rate tech in me is always looking for tricks to get these jobs done quicker. I'll take apart the original one when I have some spare time and see how bad it is. You can see in the second photo the 3 lines had quite a bit of white powder on them so I have a feeling it isn't going to be great inside the original valve. I do know that on first start up the front end came up quicker than it ever has. Sitting overnight will tell me if it's better/fixed as that is about how long it took to get it to sag.
Thanks for the tip, I have a used OEM one from Great Britain (Torx screws) and ready to install, just a bit reticent, but also have a rebuild kit for the old one!
Old Jun 16, 2021 | 12:53 AM
  #1632
enb54's Avatar
Originally Posted by Elrobo
I tore down my 4.0l in my LR3 and I found one of the valves had harpooned through the top of the piston. valve "the Impaler"
As you and I have both found out, those 4.0 SOHC Cologne engines are NOT "non-interference" no matter what the Wikipedia Ford engine site says...
Old Jun 20, 2021 | 03:51 PM
  #1633
Alex J's Avatar
It's a pretty easy job to both rebuild the valve and install it. I watched a couple different videos on the rebuild so I could see what I was getting into. Couple tricks for installing the valve, take a before picture so you know which port each of the black lines go into and put tape on one if there already isn't tape and once you have the fittings undone spray some silicone spray on the top and bottom sides of it. This will help it spin so it's easier to install into the replacement valve and also helps the o-ring on the brass fitting seal and not bind up preventing future leaks. Also remember that the fittings are mainly sealed with those o-rings so once the fitting feels snug into the block stop tightening.
Old Jun 20, 2021 | 07:55 PM
  #1634
I rearranged my rear bumper cover....
Did the Daniel Boone Back Country Byway Friday and Saturday, out in the Daniel Boone National Forest. There was pretty amazing trails out there. That new Defender though handed the LR3 and RRS their butts though. That thing walked everything except one spot that probably would have required 40's
Old Jun 21, 2021 | 02:30 AM
  #1635
loanrangie's Avatar
Time to make a steel replacement.
Old Jun 21, 2021 | 08:41 AM
  #1636
morrisdl's Avatar
I trimmed a couple inches off the bottom of my bumper and now it gets 'pants' a lot less!
Followed the molded indent almost like the original engineers were asking for it to be cut off:
"That thing walked everything" - careful what you wish for. One of my regular crew has a Rubicon on 35"s and while very impressive to watch, the driver finds it a little boring.
Old Jun 21, 2021 | 09:32 AM
  #1637
reverendALC's Avatar
5th Gear
more lights!!!
Old Jun 21, 2021 | 02:37 PM
  #1638
Originally Posted by loanrangie
Time to SELL A KIDNEY TO BUY a steel replacement.
Fixed that for you 😁
I like that nice work.
The Defender does just walk up however you have to put your mind to work to find that line for the tires to keep the clearance high
Old Jun 21, 2021 | 09:01 PM
  #1639
Alex J's Avatar
I like this, I did something similar to the front bumper of my Jeep Grand Cherokee ZJ when I had one about 5 years ago. I wish the front bumper of the LR3 was slim like the 03-04 D2's.
Old Jun 21, 2021 | 09:13 PM
  #1640
COSPILOT's Avatar
Changed the oil and front differential, on to the transfer case. Thought my son was being weak, but my lord is that drain plug way too tight. Thanks dealership…
