What did you do to your LR3 today?
Old Feb 3, 2019 | 06:55 AM
  #851
Took mine to Cars and Coffee in Augusta. Had a great time checking out the rides.
Old Feb 6, 2019 | 10:16 AM
  #852
Little spring cleaning... My rims look like scrap aluminum..
So first a bit of primer
Then a fresh coat of black
Then we pull the masking
And back on the truck
Just have 3 more to do now. Oh and 4 on the 2007...
Old Feb 7, 2019 | 07:13 AM
  #853
I diagnosed a bad rear wheel bearing so I have dug in and stripped it most of the way down last night.
Old Feb 7, 2019 | 03:52 PM
  #854
krick3tt's Avatar
Had the alternator replaced. Old one was toast, bearings were whining and when it was removed it was hot. also an oil/filter change. Discovered while it was up on lift where that click/rattle is coming from. Tail pipe is bumping against a bracket. Seems when I hit a rock and dented the pipe that it moved enough to now contact the bracket. Very annoying but at least it is not having something fall off the LR and that is a good thing.
Old Feb 8, 2019 | 06:43 AM
  #855
Rufflyer's Avatar
I finished a project to replace a few parts on the front end this week:
Rotors, hubs/bearings, half shafts, sway bay bushings, front differential,front right axle tube bearings and seals, upper and lower control arms. inner and outer tie rods, lower steering column shaft
Next up, the back end. (second verse same as the first)
Jeff
Old Feb 8, 2019 | 12:37 PM
  #856
abran's Avatar
Jeff
That's all? Under achiever...
Old Feb 8, 2019 | 08:49 PM
  #857
Wheel bearing is replaced all back together and road tested.
I only used the torch a little bit
Old Feb 13, 2019 | 02:56 PM
  #858
abran's Avatar
Where did you get the knuckle?
Old Feb 13, 2019 | 03:56 PM
  #859
That was before I figured out the machine shop screwed the bearing.
The Lucky8 guys are squaring me away on replacement bits
Old Feb 19, 2019 | 02:07 PM
  #860
Pulled a 24 foot travel trailer, back to storage. Lr3 did great and the brake controller was the right choice.
