Wind noise
Old Jan 20, 2013 | 12:10 AM
jmeyers278's Avatar
Default Wind noise
Ok. Another new noise. I drove my new to me lr3 for the first time in heavy wind and there is a wind related noise that sounds like a train whistle at 75mph. Any ideas??
Old Jan 20, 2013 | 07:38 AM
ghengis86's Avatar
Roof rack cross bars?
Old Jan 20, 2013 | 09:06 PM
jmeyers278's Avatar
dont have roof rack cross bars...sounds like it is coming from the front of the rig
Old Jan 23, 2013 | 10:02 PM
bbyer's Avatar
Default Probably A post plastic lifting at speed.
Get some 3/4" wide 3M black +33 electrical tape, and tape a strip both sides where the glass and A pillar plastic meet.
I think the plastic lifts at speed. You might also run a strip across at the top of the glass as well.
If the noise persists, then tape the movable sunroof where the glass meets the metal on all four sides.
My noise was from the A posts - I just left the tape in place as it is barely noticeable.
I also found the noise was dependent upon cross winds as well as speed.
Old Jan 23, 2013 | 11:00 PM
jmeyers278's Avatar
Thanks for the tip. Can you post a pic??
Old Jan 23, 2013 | 11:12 PM
bbyer's Avatar
Default Its winter up here - outside is no fun.
Just run a strip vertically, half of the width on the glass and half on the plastic. Actually you end up with about a 1/4" sticking to the glass, a 1/4 inch sort of in the concave and the last 1/4" on the black plastic.
Usually the first A pillar takes a couple of attempts to get it looking even; the second, well, still a couple of attempts, but the cost is minimal.
The sun roof is harder going around the curves. Usually I do both the left to right long straights first and then follow up with the shorter sides and curves with two more lengths of tape.
Tape is cheap; use the 3M Made in USA +33 brand tape; the far east sourced stuff turns gooey and or brittle with time.
twanmedley
Jan 3, 2008 11:55 AM
ryant06
Dec 27, 2007 03:29 PM
discoken
Aug 28, 2007 10:04 AM
cheatham25
Feb 16, 2007 11:14 AM
cmitty
Dec 20, 2005 01:36 AM
