Ham Radio transceiver install in LR4
Old 07-15-2010, 01:18 PM
n1dl's Avatar
3rd Gear
Default Ham Radio transceiver install in LR4
I just installed an ICOM IC-7000 and HiQ screwdriver antenna in a 2010 LR4.
If interested go to my website for pictures:
www.marcoisland.org/n1dl_mobile.htm
If you have any questions feel free to contact me.
Old 07-18-2010, 10:03 AM
NYC Ben's Avatar
4wd High
Cool! How's it work? I'm having some difficulty finding a good mount. I picked up a minimally functional Cobra (19DX IV) and the little Will antenna, but I'm struggling to come up with a good spot to mount it. Any ideas?
Old 07-19-2010, 05:56 PM
n1dl's Avatar
3rd Gear
Default installation
I am not familiar with you antenna. If its long then consider the tow mount like I have in the picture. If its a short one you can get a small mount that screws onto the top tail gate (I use one for VHF/UHF)
Does your radio have a removable control head? If yes consider a mount that uses the drink well.
Karl
Old 03-05-2017, 08:35 PM
mdlr4's Avatar
Default install 7000
hi, I got a 2015 LR4 and the same radio. can you tell me how you installed the radio? did you connect the radio directly to the battery? did you did you use a relay or switch? I'm trying to find the ignition signal wire so the radio won't drain out the battery. Do you know which wire it might be?
Old 03-08-2017, 05:56 PM
n1dl's Avatar
3rd Gear
Smile Ham Radio in LR4
I installed the IC7000 main unit in the trunk behind the plastic side panel door in a vertical position and the control head on a "drink holder base"in the central front drink well. I used the existing DC outlet in the trunk and did not install wiring from the battery. It worked just fine. I used some ferrite cores around the DC cable near the transceiver.
Have fun and drive carefully.
Old 03-11-2017, 04:55 PM
Rufflyer's Avatar
Looks good
Old 03-11-2017, 04:58 PM
Rufflyer's Avatar
Smile Nice install
Nice install. Done a similar type on my LR4
collin Barrows
06-04-2017 06:37 PM
adam123
03-24-2011 02:54 PM
Disco TN
01-18-2009 09:42 AM
landlvr
08-12-2007 07:23 PM
Quick Reply: Ham Radio transceiver install in LR4
