High beam on passanger side not working
Old Mar 9, 2023 | 03:20 PM
Banannajam's Avatar
3rd Gear
Default High beam on passanger side not working
As the title, it's just failed its inspection. Its a 2015. I looked for fuses and worked out it doesn't have one for the headlights. I then changed the main headlight bulb but the high beam still doesn't work on the passenger side
Has anyone dealt with this issue before?
The guy at the inspection place commented that there is often a small actuator that moves something that causes the beam to go higher, and it may be this that's broken.
Thanks
Dave
Old Mar 9, 2023 | 04:31 PM
jahummer's Avatar
Low beam/high beam are the same bulb, so what precisely's not working correctly?
Old Mar 22, 2023 | 05:45 AM
Banannajam's Avatar
3rd Gear
Changed the bulb and the regular headlight is working but it will still not go onto high beam. I assume there is a mechanical part within the light housing that directs the light for high beam?
No Doubt
Sep 24, 2017 08:59 PM
WYRover
Oct 29, 2014 10:29 AM
starcraft1
Dec 4, 2012 07:31 PM
Fouts
Jan 27, 2012 08:48 AM
collin Barrows
Nov 28, 2011 05:07 PM
