Low Coolant Warning - Wiring Test Help
Old Aug 15, 2024 | 04:26 PM
Bonanza's Avatar
5th Gear
Default Low Coolant Warning - Wiring Test Help
Hello,
I had the "Low Coolant Warning" but the coolant level was fine. I've changed the coolant bottle including the sensor and I still have the warning. I would like to know if the use a paper clip to bridge the 2 terminals will that bypass the sensor. I'm trying to diagnose whether I have a defective bottle/sensor or if I have a wiring issue.
I've searched through the forums but I couldn't find a testing procedure.
Regards,
Bonanaza
Old Aug 18, 2024 | 01:06 PM
jahummer's Avatar
Are you certain the float's working correctly? I had one defective once, it wouldn't float correctly and would trigger the warning.
Old Aug 18, 2024 | 01:17 PM
Bonanza's Avatar
5th Gear
The float is floating, I'd like to know how to diagnose the if the wiring or the sensor is faulty.
Old Oct 5, 2024 | 08:50 PM
AaronHall's Avatar
6th Gear
I would also like to know if this test is possible
wlindsey@gmail.com
Dec 1, 2025 08:08 PM
sayvillerx
Jul 26, 2024 04:30 PM
ljdiscovery
Sep 9, 2016 05:28 AM
MikeLi
Sep 18, 2008 10:33 AM
Max_A6
Mar 5, 2008 08:52 AM
