LR4 6-speed post zip kit, no sport mode, no codes, shifts fine
Old May 8, 2025 | 11:57 AM
jaymart1983's Avatar
3rd Gear
Default LR4 6-speed post zip kit, no sport mode, no codes, shifts fine
I recently did a zip kit on my 2013 LR4. The kit went pretty well. I took my time and made sure not to touch any of the mech unit electrical contacts. I reset adaptions and the car drove great after. Shifted smoothly through all 6 gears. The only issue I have right now is that I do not have sport mode on the dash when I move the shift lever to the left. If I bump the shift lever up or down, I get the normal message that command shift is selected and I can shift between all gears perfectly fine. After a few minutes of not shifting, it goes back to full automatic mode. I never get S on the dash. I also have no codes or other issues with the car. Sport mode worked fine before the zip kit work. I pulled the battery again for a few hours just to discharge the system and test that, no change. I have driven a couple thousand miles now so the car should have learned its adaptions. I cant find anything about this combo: S mode not showing, all gears shifting fine, command shift works, and no codes. Any thoughts? Thank you.
Old May 8, 2025 | 06:59 PM
guy's Avatar
guy
Ask Sonnax!
Old May 8, 2025 | 10:15 PM
3rd Gear
Originally Posted by guy
Ask Sonnax!
Thanks, that is on the list of things to do. I thought I'd ask the forum to see if there were less obvious things while I correspond with Sonnax.
badams67
Apr 14, 2022 08:02 PM
vvrrrmm
Dec 13, 2021 09:08 PM
sarenka123
Dec 16, 2020 12:56 PM
Tadpole
Nov 7, 2018 08:02 AM
