LR4 crank but no start after front and rear crossover pipes
Old Aug 1, 2025 | 08:10 PM
Axelander's Avatar
Default LR4 crank but no start after front and rear crossover pipes
Just replaced the front and rear crossover pipes and it went well, pressure tested with no leaks. Got everything back together and it cranked with no start which I sort of expected after having the fuel rail off for a day. Tried to prime the pump with just position 1 start a dozen times and still cranking with no start. Maybe tried 8-10 times with same result but don’t want to burn out the starter.
I double checked all connections from the install and 99% sure everything is back in place. Anyone have ideas on next steps? Ready to be done with this job my hamstrings are on fire
The truck is a 2013 LR4 with the 5.0
Old Aug 1, 2025 | 08:56 PM
Axelander's Avatar
I figured it out. Had the plugs swapped on the temp sensor and intake manifold. Fired right up when swapped. Here’s the thread that led me to this
https://www.landroverworld.org/threa...eplaced.41653/
etylowy
LR4
Jul 18, 2025 09:06 AM
irishrover25
LR4
Jun 14, 2025 11:06 PM
diesel1986
LR4
20
May 19, 2024 07:14 AM
screem22
LR4
Dec 6, 2023 08:24 AM
Zach Spencer
LR4
Jun 12, 2018 05:38 PM
