opening unlocked LR4
Old Dec 3, 2023 | 11:07 AM
roverrex's Avatar
Default opening unlocked LR4
If I don't have the key on me, the unlocked door opens normally. With the key, It acts as if the car is locked, something clicks in the door and the blinkers blink. Even if the door is open, if I pull on the handle again, I can hear the mechanism in the door clicking and the blinkers blink. Last night I saw a fault with the GAP tool, I don't remember what it said but it was something about communication fault with the key. I cleared the code and all was well but it's doing it again today...with no fault.
Does anyone have any experience with this, and is there somewhere in the GAP menu I can do something, like reset communication with the key?
edit: it's a 2013 if it matters
Old Dec 5, 2023 | 03:35 PM
abran's Avatar
Are you pushing the button on the handle wen trying to open with key on you?
Old Dec 5, 2023 | 05:46 PM
roverrex's Avatar
Originally Posted by abran
Are you pushing the button on the handle when trying to open with key on you?
no, I’m not pressing the button at all. It’s very odd. Goin to be hard to troubleshoot.
Old Dec 6, 2023 | 08:16 AM
abran's Avatar
It sounds like it thinks you are pressing the button.
you can try removing the door panel and get access to the electrical connector on the handle. Unplug it, refit the panel and test to see what happens.
or buy a used handle and swap it in. I’m guessing that’s your issue.
Old Dec 6, 2023 | 05:43 PM
roverrex's Avatar
I think you might be right. Playing with it some more, it's not pulling the door handle that triggers it, it's touching any part of the door handle at all.
Thanks for your input, I'll take a look at the connector this weekend.
Jon.P
Feb 22, 2021 05:27 AM
Mojigglins
Feb 8, 2016 07:28 PM
caymandrew
Mar 27, 2013 07:19 PM
99LRDisc
Nov 12, 2008 07:44 PM
Disco2Guy
Sep 21, 2007 09:20 PM
