P0089-64 AF and P176C-11 2C
Old Nov 12, 2022 | 07:45 AM
jkitsmiller's Avatar
6th Gear
Default P0089-64 AF and P176C-11 2C
I recently got the gap tool and when the engine light came on in my 2015 LUX I was glad to have it.
I got these two errors:
P176C-11 (2C) Transmission range selector lock control error - General electrical failure - circuit short to ground
P0089-64 (AF) Fuel pressure regulator performance - Algorithm based failure - signal plausibility failure
I've not had any issues driving, no problems shifting, nothing.
The one with algorithm makes it sound like a computer problem, especially adding plausibility.
I have an appointment Tuesday to have it looked at, would appreciate any input the much more experienced here have.
Thank you.
Old Nov 14, 2022 | 11:58 PM
jlglr4's Avatar
The P176C-11 code sounds like the shift lock solenoid. This will leave you stranded if it goes south. Just a warning - the dealer will likely want to swap out the whole control mechanism for about $1200. There is a very useful post on AULRO about the problem and possible solution here if you like to DIY: https://www.aulro.com/afvb/l319-disc...-problems.html.
The algorithm failure on the fuel pressure regulator does not necessarily mean its a computer problem. It just means the signal it is getting from the sensor doesn’t make sense (not plausible) within the parameters of the algorithm it is trying to run. So, could just be a bad sensor.
I don’t know which of these errors would have caused the check engine light.
bored4long
Feb 15, 2025 01:41 PM
NJOverland
Oct 24, 2022 09:19 PM
Matthew Lord
May 10, 2020 10:51 AM
Philip Chan
Jul 5, 2019 05:53 PM
