Rubber piece found under car after jacking
Old Dec 28, 2023 | 12:19 PM
slink182's Avatar
Default Rubber piece found under car after jacking
Today I replaced my brake pad wear sensors and when I moved the car I found a small rubber wedge type thing on the ground. I’m assuming it fell out from somewhere when jacking the car? I know it’s off the car because it has a Land Rover logo on it. The part # P00121715A stamped on the top doesn’t return any results when googled. Does anyone have an idea of what this is and where it needs to go back to?
Not sure it’s relevant but I just had the front lower control arm bushings replaced at the dealer a few weeks ago. Maybe they didn’t put it back in the right way??
Old Dec 29, 2023 | 01:34 AM
kellypleahy's Avatar
Looks like some kind of sound insulator but I'm not sure where it goes
Old Jan 6, 2024 | 10:31 AM
abran's Avatar
Looks like the blank off from one of the plastic boxes in the engine bay.
probably the driver side box that has the booster in it.
Old May 30, 2026 | 05:51 PM
RoverRuckus's Avatar
Default Found where it goes!!
I had the same issue with this rubber piece falling on my garage floor after some maintenance was done at the dealership. After a fair bit of searching I found its home. It belongs in the box housing the auxiliary battery. It is part of a two-piece block off plate right where the battery cables exit the box.
Old Jun 1, 2026 | 11:12 AM
slink182's Avatar
Default Mystery solved!
Thanks @RoverRuckus . Now, let's see if I saved that piece of rubber in a logical place so it's easy to find .
KamboMD
Dec 30, 2022 02:58 PM
Iqbalsanghera
Range Rover L405 (Fourth Gen)
Jun 20, 2021 07:33 AM
JosephCiii
Jul 23, 2019 03:50 PM
rsquare
Nov 17, 2018 01:25 PM
Mandrake
ROAMING WITH FRIENDS
Jan 14, 2009 10:52 PM
