Wipers Get Stuck on Way Down With Loud Noise
Old Aug 7, 2025 | 07:46 AM
Greengoblin37's Avatar
Default Wipers Get Stuck on Way Down With Loud Noise
All of a sudden yesterday (during a rainstorm of course), my wipers got stuck about 3/4 of the way down and start vibrating in place with a loud groaning noise that stops after a few seconds. When I got home, I manually pushed them down (they move together when pushing one so the linkage seems fine) and started the wipers again. They start and move up just fine and on the way back they do the same thing and just get stuck at the same spot with the vibration/noise.
Waiting on a tool to arrive today to remove my blades and take a look at everything, but is this just a classic case of a motor going bad? Seems weird that the blades operated fine on the way up and most of the way down, and only gets stuck in the exact same spot each time. I would think if the motor was bad, it wouldn't be able to move them at all?
Thanks!
Old Aug 8, 2025 | 12:33 AM
abran's Avatar
Most common issue is the arm,aluminum, wearing out on the wiper assembly spindle , steel.
Barring that, sounds like the linkage is hung up, maybe its rusty, got bent from being semi seized?
Invictus
Nov 22, 2021 11:31 PM
Mullins.cody
Jun 23, 2019 10:38 PM
geek_IM
Dec 21, 2011 04:12 PM
skatelove303
Apr 30, 2010 07:49 AM
