4.11 gear ratio
Old Apr 26, 2013 | 07:53 PM
OZTRAX's Avatar
Question 4.11 gear ratio
Hi Disco Mike and others,
Can you provide any info on the 4.11 gear ratio mod.
I assume this is the differential gearing (crown and pinion).
Disco STD was 3.58, L3 and defender 4.???
I'm obtaining a 2nd hand ARB locker, and may want to change gear ratio like you guys.
Does this help the lag at low revs ?
I have a TDI 300, bit doughy still in the sand, and lags till turbo cuts in after 2000 rpm.
Maybe gear ratio will help these issues.
regards
oztrax
Old Apr 27, 2013 | 06:37 AM
antichrist's Avatar
There are a number of factors that go in to choosing a different diff ratio, tire OD, engine, transfer case high range ratio and primary driving terrain. The 300 tdi has a different transfer ratio than the petrol, IIRC.
There are several final drive ratio calculators on the net.
Another factor is what you want for low range. You might choose to have a creepy crawly low range in which case you'd get a much higher diff R&P and install a lower transfer high range ratio so you keep more normal road manners.
Old Apr 28, 2013 | 07:19 AM
Also, does your Disco have CDL, which is needed to run a locker?
Old Apr 29, 2013 | 06:38 AM
OZTRAX's Avatar
yes, have cdl and no ABS,
thats the beauty of the 1995 model, 96 came out with abs standard.
so where do you get 4.11 r@p ?
off an old defender diff ?
Old Apr 29, 2013 | 09:40 AM
fishEH's Avatar
Ashcroft and GBR(Great Basin Rovers). You might have better luck with Ashcroft since you're in Australia.
Old Apr 29, 2013 | 11:04 AM
jafir's Avatar
Best bet would be to check at aulro.com for where they get their parts. That forum is huge and has a high level of participation.
Old May 2, 2013 | 02:23 PM
antichrist's Avatar
All the Rover coilers had the same 3.54 ratio as stock.
If you post on AULRO there's a good chance you'll find some a bit more local than the US or GB.
humroot
Nov 11, 2007 08:26 AM
bklahl
Sep 2, 2007 11:39 AM
bobby82569
May 18, 2007 01:30 PM
noemad
Apr 16, 2007 10:45 AM
jim_darci
Feb 18, 2007 12:11 AM
