4.6 into Range Rover Classic
Old Jun 29, 2014 | 06:20 AM
deranged rover 89's Avatar
4th Gear
Default 4.6 into Range Rover Classic
I have a 1989 Range Rover Classic and I have been told that the 4.6 from the P38 will bolt straight in. Is this the case ?
Old Jun 29, 2014 | 09:48 AM
jafir's Avatar
Not exactly. But it can be made to work.
You're talking a v-belt RRC vs a serpentine belt P38.
Front cover, distributor drive, fuel injection, etc. are all things you'd have to swap.
Old Jun 30, 2014 | 02:08 AM
4th Gear
Thanks for that, I have the serpentine belt RRC, (late 1989) and I am assuming I would have to change the computer also. ?
Old Jun 30, 2014 | 05:46 AM
Paul Grant's Avatar
1995 was the only year the RRC came with a serpentine belt. You also have to get a blocking plate for where the crank sensor is on the GEMS or Bosch motor. Personally, I'd look for a GEMS block if you have a choice.
Old Jun 30, 2014 | 05:48 AM
Paul Grant's Avatar
You will be reusing all the 14CUX EFI system so you won't need to get a new computer. Essentially, you'll want to take the intake from your '89 with the fuel rail, intake trumpets and plenum and move them over to the 4.6 long block.
Old Jul 2, 2014 | 04:53 AM
4th Gear
Thanks Guy's I will take your advice on board and let you know how I went.
badfysh
Oct 23, 2012 10:45 PM
Lincoln Tarantino
Nov 14, 2011 10:41 PM
roverfriend
Sep 26, 2010 11:04 PM
networld
Apr 26, 2009 10:09 AM
tre976
Feb 19, 2008 02:15 AM
