harbor freight Badlands winch review
Old Feb 17, 2014 | 07:05 AM
  #71
TOM R's Avatar
I actually had mine e dangerous to drive till I swapped springs after I added winch weight, was running original shocks,springs,bad tie rod end, beat panhard bushings, the weight over exaggerated the worn parts
Are you planning as lift? If so I think there was a set of ome 4 sale on disco web or landroversonly.com for d2
Old Feb 19, 2014 | 09:54 AM
  #72
EVN137's Avatar
No plans on lifting.
Right now it drives ( handles ) differently with all that weight up front. Don't have any issues with wobbles ( lots of pot holes now ). I'm thinking of going with heavy springs up front stock rear and changing to heavy shocks all around.
Will relocated the jack for the controller so it is on top of the box ( and seal the box ).
Old Feb 19, 2014 | 11:37 AM
  #73
fishEH's Avatar
You might as well lift it!! Seriously if you're going to go through all that just put some stiffer 2" lift springs and shocks on. These trucks look so much better with a moderate lift anyways.
Talk to Justin at Lucky8, he's up in your neck of the woods anyways. He'll get you set up with a suspension that fits your needs.
Old Feb 20, 2014 | 01:02 AM
  #74
CUpgt's Avatar
Agreed. Discos look SO much better lifted!
Old Apr 16, 2014 | 08:37 PM
  #75
nosup4u's Avatar
have this winch and a terrafirma bumper possibly going on this weekend, anyone done that combo? any recommendations if so?
Old Apr 16, 2014 | 09:59 PM
  #76
dusty1's Avatar
not familiar with the mounting of that bumper, but post up some after pics
Old Apr 17, 2014 | 07:12 AM
  #77
TOM R's Avatar
Winch is straight forward bolt down hook power and ground
If you have headlight sprayers need to block off the hose
Old Apr 22, 2014 | 06:41 AM
  #78
drowssap's Avatar
terrafirma bumper straight forward 4 bolts
Old May 9, 2014 | 10:24 PM
  #79
Dane!'s Avatar
Longer term review on the HF Winch?
I'm thinking the HF winch or the Smitty built XRC 12, just wondering how the HF is doing, if its going good why spend the extra $$$. I'm not doing any competitions, so no need for speed
Old May 9, 2014 | 10:43 PM
  #80
dusty1's Avatar
1st one has made 60+ pulls, since I got it. I have 3 more. (one on a work truck, one on a gooseneck, one on the back of my disco) I have only had one issue. solenoid ground wire got loose, loctite fixed it. have not had problem, otherwise......and the last one I got had that wire patched into the main ground, so they fixed my 1 minor issue.
