What Size Tire '99 Disco?
Old May 2, 2008 | 03:53 PM
dirtymorgan's Avatar
5th Gear
Default What Size Tire '99 Disco?
I have read a bunch of posts, but want to get this right. I have a '99 Disco II with the coil spring conversion kit in place for the rear. Can I go to a 245/75/16 tire and not have to do any modifications? I don't want a lift kit etc...
Thanks anyone...
Old May 2, 2008 | 08:42 PM
Default RE: What Size Tire '99 Disco?
ayes, there is no question, a 245 will fit fine and look even better.
Old May 23, 2008 | 12:55 PM
Darover's Avatar
But I would go with 255/70-16. Bigger than stock, a tinny bit smaller but fatterthan 245/75 and in my opinion, look much better.
Old Aug 8, 2008 | 02:21 AM
KarenCaren's Avatar
You could go with that tire. It will fit perfectly fine. Better let us see your truck when you fit in the tire.
______________
Must see: Autopartswarehouse.com
Old Aug 8, 2008 | 08:50 AM
If you don't want to go for a lift, at least replace your shocks so you can improve your handling over your old tired factory shocks, try either Bilstein's or OME's.
Old Aug 10, 2008 | 11:05 PM
rrhyne's Avatar
I run 255 65 r16 Michelin Cross Terrains. Not a sexy looking tire, but they are wide and served me well over gnarly rocks and sand.
EDIT, originally had written 255 75 r16. Sorry!
Old Sep 23, 2008 | 09:05 PM
tailchaser0527's Avatar
I run 265 70 16 duelers on stock susp. no problems, couldn't go any bigger with out rubbing tho..Aftermarket front bumper gives a little more clearance. But the tires worked well with a stock bumper.
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
Gordon Bombay
Dec 6, 2009 12:13 PM
apcollin
Tires
29
May 24, 2009 02:03 PM
texmanmoore
Apr 2, 2009 07:44 PM
