What Size Tire '99 Disco?
I have read a bunch of posts, but want to get this right. I have a '99 Disco II with the coil spring conversion kit in place for the rear. Can I go to a 245/75/16 tire and not have to do any modifications? I don't want a lift kit etc...
Thanks anyone...
Thanks anyone...
You could go with that tire. It will fit perfectly fine. Better let us see your truck when you fit in the tire.
______________
Must see: Autopartswarehouse.com
______________
If you don't want to go for a lift, at least replace your shocks so you can improve your handling over your old tired factory shocks, try either Bilstein's or OME's.
I run 255 65 r16 Michelin Cross Terrains. Not a sexy looking tire, but they are wide and served me well over gnarly rocks and sand.
EDIT, originally had written 255 75 r16. Sorry!
I run 265 70 16 duelers on stock susp. no problems, couldn't go any bigger with out rubbing tho..Aftermarket front bumper gives a little more clearance. But the tires worked well with a stock bumper.
jigray3
Oct 14, 2010 06:54 PM
jigray3
Oct 9, 2010 09:27 AM
texmanmoore
Apr 2, 2009 07:44 PM
