16k - No Issues
Old Mar 13, 2020 | 06:53 PM
The DareDevil's Avatar
Default 16k - No Issues
Feel the need to try and balance out this forum... I have 16k on the clock (‘18 HSE Si6) and not a single recurring issue with the truck. My only complaint was the accelerator lag when I first bought it, but that’s fixed. Towed ~6000lbs for 5000miles, so it’s not underworked, either.
Love this truck!
(Disclosure: I traded in ML350 Diesel, and purposefully opted for the Si6 given all the emissions related issues oil burners have these days).
Old Mar 13, 2020 | 10:15 PM
Bhmdisco5's Avatar
4wd High
Default 20k
20k miles and very happy. A few minor issues, rear leak in both rear windows due to water coming in from roof rack area, replacement of telematics unit, and a few software gremlins fixed by software updates. Only serious item of note in my TD6 is that everyone should check their coolant reservior, mine was basically empty and had to be refilled (non leak, just disappeared).
Old Mar 14, 2020 | 12:21 PM
n559br's Avatar
I have seen the same issue with my coolant reservoir at around 25k. Havent checked it in the last 8k or so.
Old Mar 14, 2020 | 04:24 PM
andries's Avatar
Unfortunately I can’t say the same, but the 2 biggest issues were the hood not opening and the gearshift lag at rolling stops. Dealer have fixed both. A few other ****les that were fixed, mostly software updates.
It should not loose coolant, check the oil cap for residue. Coolant disappearing is never good and can point to big issues. Keep complaining at the dealer so they can pressure test the system, etc. At least you will have it on record.
Old Mar 14, 2020 | 06:46 PM
LoneStarLR's Avatar
Only 8 months and 2.5k miles for me which is itching but so far it’s only been initial quality issues from the factory...
Old Mar 14, 2020 | 07:31 PM
n559br's Avatar
all i can say i regularly open your sun roof. I never open mine, but happened to do it last week. The thing rattled so loud we couldnt keep it open. I had it looked at during the 32k service and the dealer said the bolts holding the glass in had some loose. Wow...
MemeMagno
Mar 29, 2024 12:02 PM
TD6disco
Feb 7, 2024 04:25 PM
ToiletDuck
Mar 15, 2022 10:05 AM
findre
Range Rover L405 (Fourth Gen)
Nov 4, 2019 06:42 PM
98HSE
Nov 2, 2009 04:00 AM
