Crossbars for factory roof rail?
Old Jan 6, 2022 | 01:24 PM
  #51
1979rover's Avatar
The factory roof rails can support more than the crossbars can since they run longitudinally and are supported along their entire length.
Old Jan 6, 2022 | 01:27 PM
  #52
545moose's Avatar
So any idea what parts I'd need then, just crossbars which should be easy to get? Anyone have the part#
Old Jan 6, 2022 | 04:08 PM
  #53
ponderosajack's Avatar
Note that the factory crossbars sit at a fixed distance from from each other front to back because they have a pin on each foot that enters a small hole in the inner side of each rail.
You can look at your rails to see where this hole is.
You may be able to move them further apart if desired by drilling new holes in the rail if you are comfortable doing that but first measure the distance between rails at the crossbar locations to make sure the crossbars are long enough - the rails are not parallel to each other.
I don't recall the length of my factory crossbars to see how far they can be relocated.
They aren't like Thule or Yakima where the crossbars pass through the feet and are longer than what you need.
One think I do like about Thule or Yakima crossbars is it's easier to tie down an object to the crossbar where it protrudes outside the rail.
This is offered as thoughts to consider.
Old Jan 6, 2022 | 07:56 PM
  #54
545moose's Avatar
Great point, and that's part of the reason I think everyone goes aftermarket too with an RTT. Crossbars only also keep it lower to the roofline and less of a sail in the wind, just need enough room to get a hand in there to tighten the brackets to mount the RTT and that's it. The extra length give it support along the out edges and will prevent it from bouncing and chattering in the wind too. I think the ideal width for the bars would be 1" of extra on each side. For an aluminum-body RTT like a Alucab or Bush Co. it wouldn't matter much, but for an Autohome I want the edges making that outer contact, not a few inches into the body of it, since the tent is fiberglass.
Old Jan 8, 2022 | 02:31 PM
  #55
Scoot's Avatar
Originally Posted by 1979rover
I have the Front Runner and I quite like it. For context, I just completed a 3k mile round trip to the east coast and back over the holidays with it on.
-popping the caps off is, yes, a pain. And I don't think there is really a way to do it without breaking the tabs that hold them in. In fact, I think I broke three of the four. I, too, was concerned about this in the beginning. However, the caps are just plastic and if you removed the rack and wanted to replace them it would be easier to just buy new caps.
-with the caps removed and "innards exposed" there is no chance for water ingress. If you look closely there are drain holes in the roof rails and the "sockets" into which the bolts go are sealed.
-with the rack on I feel like I saw about a 2-3 mpg hit. And mine is a diesel. The biggest hit is when it's windy. The Disco isn't as slippery through the wind with the rack. Noise is also noticeable. Not crazy, but it's there. Also, in windy conditions it can get more noisy and the vehicle feels like it gets pushed around quite a bit more. However, I've always found the Disco to get pushed around anyway in crosswinds.
Hope this helps.
Thanks! Since my original post I actually went ahead and purchased the Front Runner. Based on my experience so far, your feedback is spot on! While I have probably spent more time researching and ordering accessories vs. using it, I hope to change that soon. Overall, I am very happy with the decision and look forward to putting it to good use (possibly on a cross-country trip as well!). Thanks again!
Old Feb 2, 2022 | 03:18 AM
  #56
JodyLR's Avatar
3rd Gear
Originally Posted by adamLeee
I’ve been super happy with the Thule aeroblades. Low profile, sturdy and minimal wind noise.
I am looking for the Thule cross bars as well. But can you open the sunroof after you have installed the cross bars?
Old Feb 7, 2022 | 01:58 PM
  #57
mxincanada's Avatar
3rd Gear
yes, no problem with the sunroof
Old Feb 7, 2022 | 07:42 PM
  #58
JodyLR's Avatar
3rd Gear
Can you share with me the model number of the Thule cross bars and the mount on the rail? Thanks
Old Feb 7, 2022 | 08:57 PM
  #59
New2LRinCA's Avatar
I ended up getting the OEM crossbars because 1/ I liked the holes to line them up, and 2/ got fed up trying to figure out the right parts and lengths of Thule (it was early pandemic and parts were scarce). If I were doing it again I’d figure out how to do Aerobar Evo. That slide in t-track is convenient.
Old Feb 8, 2022 | 05:26 AM
  #60
mxincanada's Avatar
3rd Gear
Default thule
Evo flush rail with fit kit 186070
magnetbox
LR4
Jan 26, 2020 06:59 AM
djatkinson
Sep 24, 2019 03:30 PM
Shiftonthefly1
Apr 4, 2016 03:30 PM
bcbp
Mar 16, 2013 10:18 AM
sna77
Dec 19, 2008 09:58 AM
