Disco 5 Oil Change - Motul Oil
Old Jul 12, 2024 | 07:16 AM
RichardinFL's Avatar
Question Disco 5 Oil Change - Motul Oil
Is Motul a good choice for a Disco 5 oil change (43k miles)?
I found
this deal on Amazon this deal on Amazon
. It meets the STJLR.51.5122 standard and reasonably priced, however never heard of this brand.
Any advice? Thanks!
Old Jul 12, 2024 | 09:02 AM
gmfain's Avatar
Motul is a great oil.
Not sure what engine you have though.
Old Jul 12, 2024 | 10:22 AM
Hi @gmfain
I have a gasoline engine. (V6 2020 Disco 5 landmark)
I notice this kit has a different Oil Filter than what I have, however, will the oil still be OK for my car?
Thanks!
Old Jul 12, 2024 | 10:27 AM
gmfain's Avatar
Originally Posted by RichardinFL
Hi @gmfain
Thanks!
Yes the oil will be good.
Old Jul 12, 2024 | 10:29 AM
gmfain's Avatar
Might consider this too.
https://www.blauparts.com/ravenol-mo...-0w-20-5l.html
Old Jul 12, 2024 | 10:47 AM
Thank you @gmfain
Do you happen to know which oil filter wrench is the best fit (90mm vs 90.2mm), I have two options below that are slightly different in size...
1- 90mm, 15 flutes
Amazon Amazon
2- 90.2 mm, 15 flutes
Amazon Amazon
Old Jul 12, 2024 | 10:53 AM
gmfain's Avatar
Thank you @gmfain
1- 90mm, 15 flutes
https://www.amazon.com/ARES-56026-90...dp/B07VYJKX4S/
https://www.amazon.com/FIRSTINFO-90-...7G15MJQX/?th=1
90mm is for cartridge style, I'm thinking that's what you have.
90.2 is for spin on type.
Old Jul 12, 2024 | 12:14 PM
462disco's Avatar
Motul is good oil. The newest oil spec is 03.5006 for the V6 S/C.
Castrol Edge 0w-20 EP is an excellent oil and recommended for 03.5006. You can also find this at walmart in a 5qt jug.
https://www.walmart.com/ip/Castrol-E...arts/563331326
https://www.castrol.com/en_us/united...html#tab_0w-20
Valvoline Euro 0w-20 is also an excellent oil (I currently use this). Mahle (OE supplier) OX774D is your filter. This is the filter wrench I use:
Amazon Amazon
Whichever you use, I would cut the oil change intervals in half to 8k miles if you plan on keeping the car.
Old Jul 12, 2024 | 02:03 PM
Thank you @gmfain
Thank you @462disco
I ended up ordering This Oil Change Kit from FCP Euro website.
https://www.fcpeuro.com/products/jag...hle-lm20410kt2
Kev M
Oct 12, 2025 08:18 PM
Newbote
Jun 9, 2024 02:02 PM
krazyk86cu
Range Rover L405 (Fourth Gen)
Jan 23, 2022 08:32 PM
djkronik57
Mar 17, 2017 10:28 AM
Keith Sutton
Nov 18, 2015 07:10 AM
