DIY Fix for Leaking Windshield?
I have 2020 that had a leak. Glass guy said he had a bunch of Land Rovers in after heavy rains. None had been off road. In any case, he removed and resealed the windshield. No more leaks. I don't know what else can be done.
I took my car in for a car wash in the morning and dropped it off at the dealer in the afternoon for repair work. No indication of leaking from the car Wash that morning, and when they give it back to me they said there is a leak down the front windshield... Lovely.
Is there any chance a clogged sunroof drain leaks down the front windshield? Looking at options to have the glass lifted and resealed.
It comes straight down the driver's side windshield with a little garden hose spray. I figured sunroof drain was too good to be true, although I did get some dirt up there the previous weekend. I used black electrical tape this morning on the windshield and just tried pouring a water mug into the sunroof. No visible drainage into the cabin.
The leak is due to inadequate/inferior adhesives during factory install. While using the vehicle off-road could certainly cause the leak, it isn't necessary to go off road for the leak to occur. It just increases the chances.
Depending on what state you live in, windshield/window replacements are covered with no out of pocket cost/hit on your premium. As mentioned above, make sure your A-Pillars are replaced, along withe the plastic tabs, and the rain sensing sensor is properly installed if you have someone do this job. Can't stress the A-Pillars enough as we had to have those done twice when our windshield was replaced.
Can the IID tool be used to recalibrate the windshield after it's replaced?
One glass shop Said a lift and reseal does not require a recalibration because the cameras already tuned to the glass. Does that sound accurate? I was assuming if it came off it would have to recalibrate. The recalibration is a sizable cost...
I have had no issues/discernable changes with the camera/sensors since my windshield was removed and reset.
