DIY Fix for Leaking Windshield?
Old May 3, 2024 | 05:52 PM
DVD's Avatar
DVD
Follow up on the windshield tape solution. I applied it a couple months ago, been through a couple rains and a car wash and no leaking!
Old May 4, 2024 | 12:15 PM
Elzot's Avatar
I have 2020 that had a leak. Glass guy said he had a bunch of Land Rovers in after heavy rains. None had been off road. In any case, he removed and resealed the windshield. No more leaks. I don't know what else can be done.
Old Dec 9, 2024 | 07:20 AM
TheManMac's Avatar
I took my car in for a car wash in the morning and dropped it off at the dealer in the afternoon for repair work. No indication of leaking from the car Wash that morning, and when they give it back to me they said there is a leak down the front windshield... Lovely.
Is there any chance a clogged sunroof drain leaks down the front windshield? Looking at options to have the glass lifted and resealed.
Old Dec 9, 2024 | 11:48 AM
Elzot's Avatar
Not likely the sunroof. Leaking windshields are a known problem on the Disco V. It's a problem with the windshield sealing process at the factory. Sometimes the leak isn't obvious because the water can travel along the edges of the window down into the electronics. It also isn't necessarily a lot of water, but it can still cause a lot of damage. But carpeting, etc. still may not appear wet. Did you ask the dealer where specifically the water is coming in?
Old Dec 9, 2024 | 12:40 PM
TheManMac's Avatar
It comes straight down the driver's side windshield with a little garden hose spray. I figured sunroof drain was too good to be true, although I did get some dirt up there the previous weekend. I used black electrical tape this morning on the windshield and just tried pouring a water mug into the sunroof. No visible drainage into the cabin.
Old Dec 10, 2024 | 12:24 PM
Elzot's Avatar
Originally Posted by sowrco
If the windshields are leaking after body flex why are vehicles which have never been off-road leaking? I don't accept that as a cause.
The leak is due to inadequate/inferior adhesives during factory install. While using the vehicle off-road could certainly cause the leak, it isn't necessary to go off road for the leak to occur. It just increases the chances.
Old Dec 10, 2024 | 12:27 PM
Elzot's Avatar
Originally Posted by mtaylo32
Depending on what state you live in, windshield/window replacements are covered with no out of pocket cost/hit on your premium. As mentioned above, make sure your A-Pillars are replaced, along withe the plastic tabs, and the rain sensing sensor is properly installed if you have someone do this job. Can't stress the A-Pillars enough as we had to have those done twice when our windshield was replaced.
I know that's true for cracked/broken windshields, which would be considered an accident. But I'm not sure a factory defect would be covered. Mine was covered by the dealer, since the leak was discovered before delivery.
Old Dec 11, 2024 | 08:32 AM
TheManMac's Avatar
Can the IID tool be used to recalibrate the windshield after it's replaced?
One glass shop Said a lift and reseal does not require a recalibration because the cameras already tuned to the glass. Does that sound accurate? I was assuming if it came off it would have to recalibrate. The recalibration is a sizable cost...
Old Dec 11, 2024 | 10:48 AM
Elzot's Avatar
Mine did not require calibration. Since the camera/sensors remain fixed to the windshield and a properly seated windshield should only fit one way, with precise tolerances, I don't think recalibration would be required.
I have had no issues/discernable changes with the camera/sensors since my windshield was removed and reset.
Old Dec 11, 2024 | 12:23 PM
TheManMac's Avatar
Thank you! Great info.
