Laggy Accelerator Fix?
Our is the Td6. Still haven't gotten the car back from the shop though so I can't yet detail what they did nor whether it worked...
IMPOIRTANT UPDATE:
Even though we'd had "the update" applied to our HSE Lux TD6 which was supposed to fix the issue, whatever we felt post-update (if anything...placebo?) was long since and obviously a bust. Took it back in and it turns out there were all sorts of issues to fix. They replaced the throttle body, turbo, and addressed some other issues as well. Here's the write-up:
Test drove vehicle felt lack of power. Pulled codes P0299-77. Turbo charger underboost.
Performed diesel quality test. Ordered new turbo and throttle body. Cleaned carbon build up out of intake valve cover system and installed new throttle body. Installed new turbo. Discovered turbo was leaking coolant from coolant supply line. Removed turbo and repaired leak. Installed turbo again. While removing the DPF the lines for the differential pressure sensor broke, installed new sensor. Test drove vehicle. Acceleration felt great. Rescanned for codes no codes present.
Quite a saga and they had the vehicle for 2 weeks, but I have to say it now really does feel good. It's still obviously a 3 ton truck or whatever, but it now behaves as a vehicle should: you press the pedal and the vehicle moves forward at about the rate one would expect, including from a stop or slow roll.
This may just have been a 'me' issue, but if anyone else is still suffering from this I thought it worth mentioning.
Having had a Mercedes e-class as a rental car on vacation in the UK which has a 9 speed auto and having managed to catch it out with a harsh take up on occasion I retract my comment on the Disco fix causing or revealing an occasional harsh take up. It seems to be normal.
Yeah, in certain ways, the more disconnected the operator input actually becomes from the vehicle, the more weirdness can occur. We are already disconnected from the throttle and the tranny. I can hardly wait for "virtual steering". Oh, we kinda have that too huh?
Lane Keep
Adaptive Cruise
Emergency Braking
Blind Spot
Clear Exit
Dynamic Stability
Traction Control
Brake Force Distribution
Terrain Response
Hill Climb
Hill Descent
What could possibly go wrong?
Lane Keep
Adaptive Cruise
Emergency Braking
Blind Spot
Clear Exit
Dynamic Stability
Traction Control
Terrain Response
Hill Climb
Hill Descent
I have the TD6 engine, and i have the same lagg issue, im picking it up today from the dealer and they said that its normal for "Diesel engines" and could not recreate my Issues,
anyone with a TD6 here that had the issue fixed has the PCM update somewhere?
BYW they gave me a DIscovery sport as a loaner, not my favorite to be honest.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
What is PedalBox and how does it help correct the issue? Just curious.
