Leaking Transmission on MY2017
  #21
Old 10-17-2018, 10:42 AM
danamac's Avatar
4th Gear
Default New transmission now needs replacement bolts!
My 2017 Discovery just had the transmission replaced (it was one of the leaking transmissions) and I just got a call from the dealer saying that Land Rover has put out a new bulletin for the vehicles with replaced transmissions - 8 engine bolts need to be replaced ASAP. So any of you who have had your transmissions replaced, you might check in with your dealership to get this done!
  #22
Old 10-17-2018, 10:45 AM
Hayseed_D5's Avatar
It sucks if you have one of them. However you almost have to laugh at it. Next they will say they put brake fluid in back in the transmission.
  #23
Old 10-17-2018, 12:13 PM
gclasse's Avatar
I was called shortly after the replacement of the Transmission for bolts replacement. But don't recall that they were from the engine. Most likely from the drivetrain area.
  #24
Old 10-17-2018, 03:34 PM
danamac's Avatar
4th Gear
Default Bolt replacement
You are probably right! I got my car back 2 weeks ago with the new transmission. Too bad they didn’t (know to) replace the bolts at that time. It’s a 3 hour each way drive to the dealership once again.
  #25
Old 11-17-2018, 07:41 AM
BelGSX-R's Avatar
I'm glad I was made aware of this thread. After coming back from the shop where they replaced the transmission oil pan, the leakage has actually increased => notified my service advisor and hope they'll do things right now. This is what dripped onto the floor in the span of 8 hours, 2 days after coming back from service:
  #26
Old 12-11-2018, 05:12 AM
BelGSX-R's Avatar
After 12 days at the shop, we finally have the D5 back. Based on previous reports, I was expected that the dealer would swap the transmission. It seems however that they have found a cheaper solution - putty:
  #27
Old 12-11-2018, 09:13 AM
andries's Avatar
WTF, I thought the resolution was to swap the transmission?? Putty is likely not going to last in the long run.
  #28
Old 02-11-2019, 09:27 AM
instantfob's Avatar
JB weld is the new transmission fix? I wonder if that's the method that ZF figured out when they had to re-work all these returned transmission from last year.
Interesting method to reduce the warranty cost because it took almost two weeks to get a replacement transmission and the dealer charged JLR by the hour while the truck is on the lift for two weeks.
mstarkoil
02-05-2019 02:28 PM
gbob
01-11-2014 12:19 PM
Dezautobm
12-21-2012 03:24 PM
robk1313
07-21-2008 12:58 PM
4x4freak
04-10-2007 12:55 PM
Quick Reply: Leaking Transmission on MY2017
