Leaking Transmission on MY2017
Old Oct 17, 2018 | 10:42 AM
  #21
danamac's Avatar
4th Gear
Default New transmission now needs replacement bolts!
My 2017 Discovery just had the transmission replaced (it was one of the leaking transmissions) and I just got a call from the dealer saying that Land Rover has put out a new bulletin for the vehicles with replaced transmissions - 8 engine bolts need to be replaced ASAP. So any of you who have had your transmissions replaced, you might check in with your dealership to get this done!
Old Oct 17, 2018 | 10:45 AM
  #22
Hayseed_D5's Avatar
It sucks if you have one of them. However you almost have to laugh at it. Next they will say they put brake fluid in back in the transmission.
Old Oct 17, 2018 | 12:13 PM
  #23
gclasse's Avatar
I was called shortly after the replacement of the Transmission for bolts replacement. But don't recall that they were from the engine. Most likely from the drivetrain area.
Old Oct 17, 2018 | 03:34 PM
  #24
danamac's Avatar
4th Gear
Default Bolt replacement
You are probably right! I got my car back 2 weeks ago with the new transmission. Too bad they didn’t (know to) replace the bolts at that time. It’s a 3 hour each way drive to the dealership once again.
Old Nov 17, 2018 | 07:41 AM
  #25
BelGSX-R's Avatar
I'm glad I was made aware of this thread. After coming back from the shop where they replaced the transmission oil pan, the leakage has actually increased => notified my service advisor and hope they'll do things right now. This is what dripped onto the floor in the span of 8 hours, 2 days after coming back from service:
Old Dec 11, 2018 | 05:12 AM
  #26
BelGSX-R's Avatar
After 12 days at the shop, we finally have the D5 back. Based on previous reports, I was expected that the dealer would swap the transmission. It seems however that they have found a cheaper solution - putty:
Old Dec 11, 2018 | 09:13 AM
  #27
andries's Avatar
WTF, I thought the resolution was to swap the transmission?? Putty is likely not going to last in the long run.
Old Feb 11, 2019 | 09:27 AM
  #28
instantfob's Avatar
JB weld is the new transmission fix? I wonder if that's the method that ZF figured out when they had to re-work all these returned transmission from last year.
Interesting method to reduce the warranty cost because it took almost two weeks to get a replacement transmission and the dealer charged JLR by the hour while the truck is on the lift for two weeks.
mstarkoil
Feb 5, 2019 02:28 PM
gbob
Jan 11, 2014 12:19 PM
Dezautobm
Dec 21, 2012 03:24 PM
robk1313
Jul 21, 2008 12:58 PM
4x4freak
Apr 10, 2007 12:55 PM
