My D5 build 2017 TD6 HSE Lux
See if this helps
Ok, after driving a few days to work and back.
Other than oil level sensor codes, I only have the P049B-00 code now. (with a cel)
my research points to a crack DPF. I'm crossing my fingers on this one! (that it is not)
Saga continues.
Saga continues.
Stick your finger in the tailpipe (when it's cool). If the DPF is cracked it will let through a tiny bit of fine black soot. I asked my buddy to do the same with his 100k/mi F250 diesel and the tailpipe is as clean as it was brand new.
I get the occasional DPF inefficient code that goes a couple months between lighting up. I've been waiting for it to pop up for the last 3000 miles before the 80k federal emissions warranty is up, but wouldn't you know it's been off with only 800 miles left. Frustrating.
here is result of finger test:
Yeah, that's how mine looks too. I'm not looking forward to that repair bill.
I spent a fair amount of time going over the service manual for the D5 just now... I was under the impression that the DPF was immediately after the DEF injector. Turns out that's the SCR (selective catalyst reduction). The DPF is closely coupled with the turbocharger and the exhaust gasses for the EGR are pulled right after the filter. If the DPF is cracked that could lead to fouling of the EGR valve and intake manifold.
Last edited by Chucktastic; Jun 16, 2024 at 09:32 AM. Reason: additional information
If I remove it the DPF guys in Atlanta will clean it for $750, but if it's cracked, that's a whole nother story.
Update on P049B-00. Last week I drove a couple days at 2500-3000 for 10 minutes. both drives, she did a regen cycle.
I've been doing more research on delete. I found https://www.velocityap.com/shop/?pro...ory=land-rover
Velocity Automotive Performance can provide a DPF/EGR/DEF delete with there tune, but you have to block EGR, gut dpf, scr, cat.
That's where it gets complicated, you have to cut and reweld ..... Finding a shop to break the law might me difficult.
( just to be clear these tunes and deletes are for off road use only)
Stay tuned.
Any comments are welcome.
Stay tuned.
Windshield Wiper change position instructions.
open driver door
foot off brake
press start button
4-7 seconds
press start button
hold wiper stalk down, other hand press start button
wipers will be in change position
don't close door or press start button until you are finished changing wiper blades.
open driver door
foot off brake
press start button
4-7 seconds
press start button
