My D5 build 2017 TD6 HSE Lux
Old Dec 22, 2020 | 09:19 AM
  #71
gmfain's Avatar
I had this come up:
incorrect diesel exhaust fluid quality detected no start
Took it to my mechanic....... Bad Def Fluid Pump (LR084743) Parts and labor $ 954
I thought I would share.
Old Dec 22, 2020 | 10:14 AM
  #72
TexasLandmark's Avatar
That's nice that the pump is seperate... most i deal with are a pump, level sender, heater, and quality sensor all in one and significantly more expensive
Old Dec 26, 2020 | 03:29 PM
  #73
cru_jones's Avatar
Originally Posted by gmfain
I had this come up:
Is that not something warranty would cover at 3 years old? Or at least an extended warranty?
Old Dec 26, 2020 | 04:05 PM
  #74
geekinc's Avatar
Maybe the extended warranty, but factory warranty is up at 50k, this Disco is at 61k miles.
What I'd like to know is how difficult the replacement would be at home?
Old Dec 27, 2020 | 08:43 AM
  #75
gmfain's Avatar
Not difficult. Driver side, remove debris shield, pump is is at DEF tank. easy.
Old Dec 27, 2020 | 09:12 AM
  #76
ar077's Avatar
UH OH! I gather that means that those of us who've replaced the debris shields with Lucky8 Rock Sliders would have to drop the driver's side rock slider (each side weighs about 100 lbs.) to get to the DEF pump. Good to know that now in case I ever have that problem. Thanks for the info, gmfain!
Old Dec 29, 2020 | 02:27 AM
  #77
gmfain's Avatar
Yes, you are correct, you have to drop the slider.
Nice rig
Old Dec 30, 2020 | 07:44 AM
  #78
1979rover's Avatar
I wonder if this would/should be covered by the emissions warranty?
Old Dec 30, 2020 | 11:59 AM
  #79
gmfain's Avatar
I wish.... here is what's covered:
Certain emission-control parts, including the vehicle’s catalytic converter, engine control module and transmission control module, are covered for 8 years/80,000 miles.
3 things, thats it.
Old Dec 30, 2020 | 12:14 PM
  #80
ar077's Avatar
3 things, thats it.
Also good to know. Thanks for the info!
